Philips 42PFL3603D/27, image trouble when first powered on
  • Modify_inc
    • Feb 2014
    • 17
    Hello all! It's hard to describe what the TV is doing so I have pictures, and also two video links to YouTube to see it in action.
    I've had the TV since 2009 and have hardly used it—maybe 15 hours. I keep it plugged up, which now I wish I hadn't.
    Last week I turned it on and noticed the screen was like a solid aqua color, while about an inch of the top was something a little different. If I turn the TV off after a few minutes and back on, it seems to get progressively better, but I have to power cycle it every few minutes to notice any changes it seems. If not, it seems to hang in the same bizarre state with subtle movements in the patterns or colors. In the first video, you can see at the 1:55 point where I power off/on the TV, and though it's crappy, I finally get a recognizable picture.
    The issue happens whether cables are attached or disconnected. Also the sound works fine.
    Here is the link to my video on YouTube that shows what happens when I turn it on. https://youtu.be/zVSWDqoUiic
    At 1:55, I turn the power off and back on, and you can finally see the menu though it has major noise and lines flashing all over it.
    The 2nd video shows it working better after twenty or so minutes but still with heavy flashing lines and other strange artifacts. https://youtu.be/L33QPISdVwM
    Pictures of my TV with the back panel removed are attached.
    Everything looks clean and I didn't notice any blown or failing capacitors or other damage on the boards. I couldn't check the t-con board because I don't know how to access or remove it. It seems to be in a difficult place to get to as you can see in the picture. Any suggestions for the t-con board? I want to try replacing it because I feel it's the likely culprit, and mostly because it's a cheap. I found a new one for 20 bucks.
    I have a multimeter, so I can test points on the pcb if someone doesn't mind suggesting what I need to test. The owner's manual is useless in this regard. How do you find a more technical manual for your TV, like something you can actually troubleshoot your TV with?
    Thank you
    Mike
  • CapLeaker
    Leaking Member
    • 8352
    Re: Philips 42PFL3603D/27, image trouble when first powered on
    You could measure the lvds on the oscilloscope, but I would reseat the lvds cable on both sides then replace the Tcon.
    • Modify_inc
      • Feb 2014
      • 17
      Any suggestions for the best way to remove the tcon from this TV?
      • CapLeaker
        Leaking Member
        • 8352
        Maybe look for a service manual?
        • Modify_inc
          • Feb 2014
          • 17
          TV manufactors seem to only offer owner manuals, which are basically useless for anything beyond general troubleshooting. Where do you find service manuals, do you have to be a certified TV repair person?
          Google didn't offer much, but maybe I should search again.
          • CapLeaker
            Leaking Member
            • 8352
            Sometimes, like in this case, you have to figure out what "Chassis" the TV is based on. For example yours is a LC8.1U LA. I am not sure about the LA on the end as there is another one. Google that and you will find it.
            • Modify_inc
              • Feb 2014
              • 17
              Ok, thank you. I had no idea you could look them up by chassis type. I will see what I can find. Thanks again!
              • alro7779
                Philips 32PFL4901/F8 BA5DFGG0201 1 Backlight is present but no image
                by alro7779
                Hello there!
                Have this Philips with no image at all. When I plug it to the outlet, it turns on without pressing the power button, and after a moment, it turns off, then starts again. I checked the 12v and 3.3v voltages on the main board connector that goes to the T-con, but it only has the former (12v). Any clues, guys?...
                08-07-2025, 11:53 AM
              • tuner2000i
                Philips 65PUS8518/12 distorted image after main board replacement
                by tuner2000i
                hello everyone,
                I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                07-15-2025, 01:15 PM
              • malekservis
                Philips 58PUS8536/12 Backlight ok, no image
                by malekservis
                the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                Any information would be appreciated....
                08-07-2024, 07:48 AM
                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:20 PM
              • Kartowl
                philips 47pfl6158k/12 image faded away, sound still coming from TV
                by Kartowl
                Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                04-23-2024, 12:57 AM
