LG LCD 47LM5850 Contrast/Picture very white
  • tech2014
    • Aug 2014
    • 807
    I have an LG LCD Tv that has a picture problem. The picture is very bright white, possibly a contrast problem. Would the T-CON be responsible for this or the main board? See pic of screen below.
    Re: LG LCD 47LM5850 Contrast/Picture very white
    Looks like bad GAMMA ref Voltages on the T-CON. Pictures of the T-CON BOARD?.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Originally posted by budm
      looks like bad gamma ref voltages on the t-con. Pictures of the t-con board?.
      +1
      • tech2014
        • Aug 2014
        • 807
        Hi guys. I replaced the TCON board and no change, screen is still the same.
        What else could cause this? A bad LVDS or main board? A bad panel??
          Check the GAMMA DCV on the GAMMA Voltage test points of the old board and the new board.
          • tech2014
            • Aug 2014
            • 807
            ok how do I go about this. I don't see anything on the TCON that says gamma.
              That is why I asked for the pictures of the T-CON board on post #2 to check the Voltages.
              'Looks like bad GAMMA ref Voltages on the T-CON. Pictures of the T-CON BOARD?.'
              • tech2014
                • Aug 2014
                • 807
                Sorry budm, I was having issues with my computer yesterday. Here are the pics of the TCON.
                • tech2014
                  • Aug 2014
                  • 807
                  Can anyone offer some guidance on this tv? Could it be a main board issue or panel?
                    Too bad, there are no known test points for the Gamma ref Voltages.
                    • tech2014
                      • Aug 2014
                      • 807
                      Hi guys. I replaced the TCON and Main board in this TV and the screen is still the same. What are the chances of it being the LVDS cable from the main board to the TCON?
                      Is there a way to rule out the LVDS?
                      See pic below. There are a lot of vertical lines on the screen. Sorry about screen, customer brought it in this way.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Why did you replace mainboard ? Check the tab bonds see if they are intermittent.
                        • Daren87
                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                          by Daren87
                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                          08-13-2023, 03:25 PM
                        • kca
                          by kca
                          Hello all ~
                          08-31-2025, 06:38 AM
                        • iglitare
                          by iglitare
                          09-04-2025, 07:13 AM
                        • TerraPhantm
                          Sony A8H to A80J mainboard upgrade possible?
                          by TerraPhantm
                          I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
                          So I decided I'd experiment a little bit.
                          I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
                          When...
                          08-15-2023, 08:10 AM
                          MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                          This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 07:46 AM
