TCON ,t -con t370hw02
  • xxcxx
    • Feb 2013
    • 31
    • portuguese
    I was to repair the TCON ,t -con t370hw02 V402 37t04 - c02.
    Change the CHIP AS15. when removed chip , one capacitor
    SMD C246, is desoldered i was loose and lost now do not know the value. The card is operational with new chip just missing the capacitor , someone say what the value of the capacitor ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: TCON ,t -con t370hw02
    The cap is for decoupling it will probably be fine with out it.
      C246 is connected in parallel with C272 so they are the same value, they are filter caps for VCOM+ on pin 39 as suggested.
      • tralboris
        • Feb 2017
        • Ukraine
        same C212 parallel
        • tralboris
          • Feb 2017
          • Ukraine
          same C212 parallel - 100nF
          • kca
            by kca
            Hello all ~
            08-31-2025, 06:38 AM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • advant
            by advant
            02-03-2020, 12:25 AM
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
          • netgearnetgear
            TCL 43S423 TCON OR PANEL FAULTY???
            by netgearnetgear
            Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
            08-20-2025, 06:04 PM
