Bush s642f dead no standby light
  • Rickig
    • Mar 2015
    • 112
    • England
    Hi guys
    I have the above set that when plugged in I can hear the psu hum but get no standby light.
    The 5v standby voltage is down to 1.5v.
    0.8v to the on/off pin
    No other voltages.
    Replaced all the domed caps on psu & still same.
    Suggestions?
  • CapLeaker
    Leaking Member
    • 8352
    Re: Bush s642f dead no standby light
    unplug the main board and measure the STBY voltage again on the PSU.
    • Rickig
      • Mar 2015
      • 112
      • England
      Same
        Time for good clear pictures of the whole back side of the TV so we can see all the boards and then good clear pictures of the top and bottom side of the power supply board to start with.
        • Ukdigger
          • May 2020
          • 121
          • England
          I've just fixed a Bush S642F - PSU - JSK4260-050A - REV:1.3. The standby light was flashing red, on and off repeatedly and the standby voltage was jumping between 1.5 and 3.5 volts. I changed the 3 caps behind the connector block, (I think it was PL807) and then got a steady 5v reading and a solid red standby light. The TV powered up ok with a blue power light, but it wouldn't get a signal to tune in the TV stations. It worked fine with a Youview box through the HDMI so I sold it to someone who just wanted it for his PlayStation.
          • mecha1166
            QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
            by mecha1166
            I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
            03-28-2024, 08:31 AM
          • esqmooo
            HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
            by esqmooo
            Hello everyone.
            This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
            Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
            Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
            I tried long pressing on the power button, after several seconds it would go off then when the button is released...
            03-11-2025, 03:57 PM
          • wushumike
            LG 65UB930T - Standby Light can trigger but TV dead
            by wushumike
            The problem: When remote controller is press, the TV seems to wake from standby light goes off; but there is no backlight, image and sound. The relay did click on.
            I have removed the power board to check. Using 2 x 10K resistor from 3.5V to PWR_ON AND DRV_ON, all the voltages is correct.
            The main board has a red LED and is lited, but the optic link does not light up.
            The Power board after sometime will start to blink x 5 interval.... I would assume this is to indicate DRV_On not working.
            Any expert here came across the same problem? I...
            03-27-2023, 09:46 AM
          • ChristianBr01
            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
            by ChristianBr01
            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
            04-23-2025, 01:48 AM
          • shagster
            TX-P50UT30B Dead - No Standby light.
            by shagster
            Hi, haven't been on the forum for a while. But I thought I'd ask here incase this has already been solved.
            Anyway, I have this Panasonic TX-P50UT30B. It's completely dead, no red standby light, nothing. I took off the back and had a look at the fuses. All of them are intact. No shorts when testing the mosfets of the Power supply either.
            And the capacitors look fine also.
            I'm guessing it's a main board issue. But I don't really know tbh. Maybe a corrupt firmware flash, dunno.
            02-27-2023, 10:07 AM
