Wharfdale no sound through HDMI
  • diif
    • Feb 2014
    • 6978
    • England
    I have the first ever TV i recapped back with me after lending it to a friend.
    Connected with scart the TV works with sound and picture, however when i connect through HDMI i get a picture but no sound. instead there is a rhythmic pulsing ever second or so.
    It's using a 17MB15E-5 mainboard.
    Does the main board need recapping or is there anything else i can check ?
    Thanks.
  • wills123
    • Jan 2014
    • 72
    • england
    Re: Wharfdale no sound through HDMI
    Have u ruled out the obvious and tried another hdmi cable and another input device?
    • diif
      • Feb 2014
      • 6978
      • England
      Yes, tried other cables, and as well as my Tivo and output from my laptop.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Try factory reseting the tv. To do this press on the remote in the following order:
        Menu
        4725
        A service menu should appear
        You should see an option that says "reset"
        Select reset and wait for the tv to reboot.
        Check if the audio comes back if not you more than likely have a hardware failure.
        • diif
          • Feb 2014
          • 6978
          • England
          Cheers RecceyBurger, i've just tried that and it's definitely hardware failure. Still no sound and as i increase the volume on the remote the volume bar display freezes in sync with the pulsing buzzing sound.
          Could it be a partially damaged HDMI chip ? The picture works with HDMI and if i connect the TV through scart the sound works great.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Hmm does sound like the Hdmi controller or a bad cap on the decoupling stage for it. Possibly you could try heating it to see if audio comes back ?
            • diif
              • Feb 2014
              • 6978
              • England
              I'll try with some heat tomorrow, just seems strange i get a picture and no sound. I've encountered blown HDMI chips in the past but they were no sound and no picture. I might test a few of the small caps around that area to see what they are like.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Possibly does sound like a Hdmi chip failure, let us know buddy
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Will do, cheers Reecey.
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
                  • japlytic
                    Not all TVs can handle surround sound on a HDMI input
                    by japlytic
                    With a home theatre PC connected to a TV via HDMI, Windows reveals that the TV only supports stereo sound even though the TV has a HDMI ARC connection to an AV receiver which is powered on; I also had an issue that the AV receiver does not always retain the input setting for routing the HTPC video through to the TV in standby.
                    So I connected a second HDMI cable to the HTPC and set it to duplicate the video outputs, but I had random audio dropouts when playing content with surround sound being passed to the AV receiver (dropouts did not occur when I replayed the content where it dropped...
                    08-31-2022, 10:09 PM
                  • CraigR
                    lg 46LD550 HDMI no sound
                    by CraigR
                    I got in a LG with no signal on HDMI ports so I replaced the HDMI IC and now I have picture but no sound on just the HDMI the other inputs are working fine for sound. Any ideas? Would the amplifier ic have anything to do with just HDMI?...
                    10-05-2022, 01:13 PM
                  • LEECH666
                    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                    by LEECH666
                    Good day ladies and gentleman!
                    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                    01-19-2024, 05:46 PM
                  • aliougm
                    Marantz SR4003 AVR HDMI board issue, seeking for help
                    by aliougm
                    I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                    Connection as below:
                    Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                    If I bypassed AVR then HDTV screen color be good.
                    I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                    3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                    I replaced all...
                    04-30-2022, 12:21 PM
