Insignia ns-32d20sna14 wont power on
  • tallica2002
    • Oct 2015
    • 17
    I have this Insignia tv and all I get is the standby light continuous red power button and remote has no effect, took it apart and it has what appears to be a power supply and a main board. I am wondering where I can start in troubleshooting it with multimeter. I have included pictures of the boards. Thanks in advance.
  • tallica2002
    • Oct 2015
    • 17
    Re: Insignia ns-32d20sna14 wont power on
    Update I found out how check for voltages I learned that you have to use a ground from cold side all my 12v have 14v all my 5v have 5v p/on had 5v even if you pressed power on/off had .04v even with power button pressed. Please point me in the right direction. I think its the main board myself.
    • bikerbuddy
      • Jun 2011
      • 134
      tallica2002 please post picture of the whole back of your TV and individual board so we can see all your connections .
      • CapLeaker
        Leaking Member
        • 8155
        That can't be, unless the PSon is active low. You would have to verify that. So measure all voltages again and post them here with the pin out names, tv on, tv off...
        • tallica2002
          • Oct 2015
          • 17
          Ok you are right as you see I am still learning I have checked voltages again and I also have a new update while trying to get these voltages the tv actually powered on and all the 12 volts went back to being 12v instead of 14 or 15 so all the on voltages i have listed are when the tv would not actually power on but pushing the power button would change the voltages. I hope you guys understand what Im talking about cant seem to get it to act up again but my mom said the picture would be scrambled sometimes and getting it to come on would be hit and miss.
          connector 2
          OFF On
          GND 0 0
          GND 0 0
          5v .01 5
          5v .01 5
          p/on .07
          5sb 5
          5v .01 5
          5v .01 5
          GND 0
          GND 0
          GND 0
          12v 0 14
          12v 0 14
          Connector 3
          off on
          12v 0 14
          12v 0 14
          gnd 0
          gnd 0
          connector 4
          off on
          12v 0 14
          12v 0 14
          on/off .01 .04
          adj .01 .04
          gnd 0
          gnd 0 0
          • tallica2002
            • Oct 2015
            • 17
            guess i edited once too many the adj on connector 4 was .02 instead of.04 after power was pressed and p/on was 4.94 after power was pressed and all the 5v were actually 5.18
            • simplytrini
              • Jul 2011
              • 73
              Hi Tallica2002, I beleive you will probably need to replace the eeprom on the main board if you can find one. Can you please post pictures of the set if you can.
              • CapLeaker
                Leaking Member
                • 8155
                The p/on pin doesn't change at all? Take a can of air upside down and spray the eeprom. Turn the tv on and see what happens.
                  on/off .01 .04. This the Backlights ON/OFF pin, it is not getting the command form the main board.
                  adj .01 .04'. This is the Backlights diming control pin, it is not getting the command from the main board.
                  So you do have main board problem, so as others had indicated, EEPROM or something else on the board went out.
                  • tallica2002
                    • Oct 2015
                    • 17
                    ok can this be hit or miss because the set has been working for the past 2 hours and seem to be fine at the moment. Should I do the can of air with the set on and working or what? What does the eeprom look like? can someone highlight it or something on one of my pics.
                    • CapLeaker
                      Leaking Member
                      • 8155
                      Since the tv is working again, make sure all connectors are clean and properly seated and all the board screws are tight.
                        Since the TV is working again, can you please verify the DCV of the P/ON pin?
                        • tallica2002
                          • Oct 2015
                          • 17
                          5v
                            5v
                            Thanks, so it is active HIGH for the PS-ON signal.
                            • tallica2002
                              • Oct 2015
                              • 17
                              well 4.92 to be exact.
                              • tallica2002
                                • Oct 2015
                                • 17
                                I have an update tonight after the tv has worked fine for the past few days it decided to freak out it made a pop noise which I think came from the speakers it turned green and scrambled picture I tried to take a picture of it but it cut off before I could and then it restarted and everything was fine again.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Sounds like a intermittent voltage reg on the Mainboard.
                                  • tallica2002
                                    • Oct 2015
                                    • 17
                                    is that something you can replace or replace the main board
                                    • tallica2002
                                      • Oct 2015
                                      • 17
                                      I was finally able to get a picture of it doing what I described it did this 3 times in a row scrambled picture and restart.
                                      • tallica2002
                                        • Oct 2015
                                        • 17
                                        now its back to not coming on at all so everybody pretty much agrees its the main board?
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • cajoeg
                                          Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                                          by cajoeg
                                          Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                                          The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                                          02-10-2025, 04:01 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
