Vizio E390 A1 issue.
  • George Request
    • Oct 2015
    This has been bugging me and I have had a hard time figuring out what I need to replace.
    It powers on according to the power light, but no screen image appears.
    When plugged in, the power light comes on and then fades. When I press power, the light stays on.
    Once on, it cannot be turned off unless unplugged.
    I cannot tell if it has audio or not.
    It does not have backlights.
    It does not have a picture when tested with a flashlight.
    This was not a problem that occurred suddenly. This was a problem that I resolved by unplugging and then plugging back it. Over time, I had to unplug it and turn it on, unplug it and turn it on. This needed to be repeated more frequently until eventually I gave up.
    Re: Vizio E390 A1 issue.
    Mai board problem, probably EEPROM.
    http://www.shopjimmy.com/catalogsear...=Vizio+E390+A1
    From shojimmy:MPORTANT:
    These main boards can have multiple failures, in addition to the EEPROM.
    If EEPROM replacement does not repair your board, there are likely additional problems.
    Symptoms EEPROM replacement MAY fix:
    - On screen display is stuck on logo screen
    - TV won’t power on with remote or buttons (LED indicator remains same color)
    - TV won’t turn on after being off for 30+ minutes
    - TV shuts off by itself during channel scan or when switching inputs
    - TV turns on and is stuck in color test pattern mode forever
    - TV turns on but there is no backlight (LED indicator shows TV is on but there is no image)
    • crosstalk
      • Feb 2014
      • 68
      • Usa
      Yes, it's likely u409. There are a couple of versions of the mainboard so be sure you get the correct programmed replacement. In my case, the IC was ok but had a few bits flipped.
      • jlapage
        • Jan 2019
        Anyone happen to know who makes U409? And what the pin out is as well as which leg does what (which one has voltage so on and so forth).
        E390-A1. When plugged in, gets the white power light. No backlight, no audio, no picture. Have already replaced power supply board, issue remains the same. FOr the heck of it, tested all the video inputs using a Sencore Video Tester - still no video. Have heard that U409 goes bad. Also heard that EEPROM gets corrupted and that reflashing solves this issue. Main Board part number is: 756TXCCB02K042.
        • nomoresonys
          • 12331
          • U.S.
          A bad/faulty capacitor can produce these symptoms also.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            I too have come across a faulty capacitor producing this symptom.
            • jlapage
              • Jan 2019
              Bad/Faulty Cap? On the main board or power supply board? Happen to know which cap it is?
              • jason123
                • Oct 2015
                • 1154
                @nomoresonys @Andrew F. Ali
                Can you please share info on this bad cap? I have the same issue, EEPROM replacement didn't fix the problem. TV occasionally turns on.
                Also, does anyone have the EEPROM Dump for E390-A1 756TXDCB02K012?
                • nomoresonys
                  • 12331
                  • U.S.
                  Maybe check the 4 electrolytic caps closest to CN801 connector, check the capacitance and esr both if you have the tester/testers.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • edgarmg15
                    Damaged EEPROM on TV Vizio E320-A0
                    by edgarmg15
                    Hi everyone
                    I´m trying to repair a TV Vizio E320-A0 that I found in the street
                    The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
                    The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
                    So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
                    11-19-2022, 03:46 PM
                  • cajoeg
                    Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                    by cajoeg
                    Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                    The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                    02-10-2025, 04:01 PM
                  • EazyBone
                    Vizio P759-G1, Tcon issue?
                    by EazyBone
                    Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
                    Any help appreciated
                    https://youtu.be/tPeV2Q7TXIQ?feature=shared
                    03-22-2024, 03:25 PM
                  • ntec
                    LED light issue
                    by ntec
                    Hi, I'm trying to fix my buddies rechargeable led work light made by olight and the model is odiance. For some reason now after a couple years of no issue, when powered off now, the led is faintly lit on 3 of the orange rows but as you can see from the first pic that's not where the leds are. The part that is faintly lit is beside the leds? Anyone know how that is possible? Is there small voltage still coming in somehow? The third pic is with the cover off....
                    10-13-2024, 10:33 PM
