Damaged EEPROM on TV Vizio E320-A0
  • edgarmg15
    • Sep 2022
    • México
    Hi everyone
    I´m trying to repair a TV Vizio E320-A0 that I found in the street
    The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
    The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
    So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a) can´t read the program from the original EEPROM because it is damaged (also I probed the programmer with another EEPROM and it worked without problems).
    So I wondering if could anyone share me the .bin file from the EEPROM.
    TV model: E320-A0.
    Main board model: 3632-2302-0150.
    Thanks in advance.
    Greetings.
  • Diah
    • Feb 2013
    • 6460
    Re: Damaged EEPROM on TV Vizio E320-A0
    try freeze the eeprom then you can read it.. if it didn't have surface damage..
    other wise i am sure i read before many years here was post in the forum a dump too.
    edid: here the dump
    • edgarmg15
      • Sep 2022
      • México
      edid: here the dump
      Thanks dude...
      I didn't knew that trick .
      I think the best I can do for now is to freeze the EEPROM because the shared zip file corresponds to another main board model so I think is a bad idea to use it in my EEPROM
      • papillon
        Vizio D50u-D12 damaged mainboards?
        by papillon
        Hi, I am troubleshooting a damaged Vizio TV (D50u-D1). Here's an overview of the troubleshooting I did with the unit when it was presented to me:
        1. TV powers on and back lights turn on, with normal brightness. The large Vizio logo is displayed. After a few moments (presumably when the TV is looking for inputs), the backlight turns off and the TV goes dark. No further message is displayed on the TV. Since the logo was displayed, I concluded that the power board, LED driver board, screen, LEDs and T-con board were all working fine.
        2. Although parts of the main board were working fine, I'm assuming
        03-10-2023, 07:01 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • RDC55
        Vizio a320-a0 eeprom
        by RDC55
        I was trying to repair this Vizio 32 inch and have isolated it to the EEPROM. The symptoms are it does not respond to the power button and so no backlights or any indication that the button was even pressed. Applying freeze spray to the EEPROM while the set is unplugged, and then plugging it in and all is well.
        Now I know I can buy pre-programmed EEPROMS for $15.00 or so, but I wanted to do this myself. So, the original EEPROM is Winbond 25Q64FSIG. I ordered this but received a 25Q64JSIG, which has slightly different timing characteristics. Well, being hopeful...
        04-28-2021, 09:06 AM
      • SidneyCanadas
        93C46 and 93C56 EEPROM
        by SidneyCanadas
        I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
        https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
        Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
        06-14-2023, 01:16 PM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
