Sharp LC-60LE847U
+ More Options
Posts
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Sharp LC-60LE847U
    No standby, no power led. Dead. Several obervations. I have 120 volts at input plug, but as I check components from fuse on, all is 60 volts AC to chassis. Makes no difference if I unplug all connectors to other boards. When Testing R7002, which does not look like a resistor, I have 120 volts on one side and milivolts on the other side. Could this be a fuse? Also have three MOVs. One at main fuse measures 1.5 megohms..other two which are parallel downstream measure less than 1 ohm.
    Next will check for standby voltage, 3.3 volts, 13 volts.
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Re: Sharp LC-60LE847U
    My apologies for not including pics!
    • ljintexas
      LJinTexas
      • Jan 2015
      • 669
      Performed reset by holding vol down and input keys while applying ac voltage. Green LED on main board blinking..after 5 min got two slow blinks followed by two fast blinks then two slow, two fast blinks of chevron V below Sharp on front panel.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Evidently, that indicates the lack of the 13.2 volts from smps which I verified on pins 5,6,7,8. Now to try and find the 13.2 volt section of the board. Any ideas?
        • gravesent
          • Oct 2015
          • 11
          I'll take a look and let you know what I find.
          • gravesent
            • Oct 2015
            • 11
            So I have highlighted what I would check to make sure they're not dead shorts or low.
            • ljintexas
              LJinTexas
              • Jan 2015
              • 669
              Pins 5,6,7,and 8 are all common to the center leg of D7130 which is the 3 leg FET
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                They are also common to the far right leg of Q7120, the 4 leg transistor is it?
                • R_J
                  • 9516
                  I did find a bulletin on this power supply, It may help. or not. Also when measuring voltages in the primary or HOT side of the power supply, you don't use chassis ground as a reference, you need to have your ground probe on the hot ground, usually the large main capacitor (-)
                  • ljintexas
                    LJinTexas
                    • Jan 2015
                    • 669
                    It would seem the 4 leg regulator may be the issue..KIA378R12PI.
                    Vout is what is common to all of the 13 volt pins..measure Vin to Vout and I get 2.6 MegOhms..I think this may be a problem.
                      What do you have on the Vin of that 12V LDO IC (KIA378R12PI), and the control pin?
                      What DCV do you have on the connector between the power supply board and the main board when power switch is not activated/activated.
                      Make sure to list the pin numbers and the pin names and follow by the DCV reading of each pin.
                      I.E.
                      Connector PD
                      Pin 1 (5VSTBY) = xx V.
                      https://www.badcaps.net/forum/showthread.php?t=49088
                      • ljintexas
                        LJinTexas
                        • Jan 2015
                        • 669
                        I had it pulled out of circuit, but put it back in circuit to check voltages.
                        will post results
                        Thanks Bud
                        • ljintexas
                          LJinTexas
                          • Jan 2015
                          • 669
                          All of the 13 volt pins are common to the Vin leg of the LDO IC. That would suggest that it is not GETTING 13 volts..there is a bank of 470 x 25 volt electrolytics next to it, of which some of are in circuit with the LDO. Hmmmmm
                            Need to get good well focused pictures of the bottom side of the board so I can do the reverse engineering. More likely the SMPS is not running that is why there is no 13V at the input pins of the 12V LDO.
                            • ljintexas
                              LJinTexas
                              • Jan 2015
                              • 669
                              I checked D7805, it passed a diode test..so much for the TSB. I reinstalled the heat sink with both ICs and re-installed in TV. SMPS is running as I tested with main board connected and disconnected.. I now have my 13 volts to pins 5,6,7, and 8! maybe cold solder joint? Upon first fire up then I got 2 then five flashes which indicates:
                              DET_PNL12V (34pin) failure (L). Panel power is not
                              applied.
                              Detection is started after turning on the panel power and
                              receiving command; the power is turned off by polling.
                              Rebooted tv by cycling power..now no error codes but no display.
                              Thanks Bud! I appreciate your help!
                                So do you have 12VDC at the output in of the 12V LDO?
                                Connector PD pin 1, 2 PNL_12V.
                                DPS-140TPA.
                                Pictures provided by SHOPJIMMY.
                                • ljintexas
                                  LJinTexas
                                  • Jan 2015
                                  • 669
                                  Yes, I do Bud. However there seems to be something going on as every few minutes I lose it for a short time then it comes back. Almost like something is shutting down then restarting. I also measured the FETs under the heatsink in the center of the board. When I have 12 volts on PD 1,2, I have 404 volts on the top FET in the center..when I lose the 12 volts, it goes down to 250 volts. When 12 volts comes back, I have 404 again.
                                    I am not sure which FET you are talking about and 404 Volts is way off to be that high without damaging the components.
                                    • ljintexas
                                      LJinTexas
                                      • Jan 2015
                                      • 669
                                      Q7601 has 404 volts on the center leg.
                                        OK, the Power MOSFET Q7601 and the Q7602 (these two MOSFETs run off the 400VDC PFC Voltage booster circuit (Q7801) drive the power transformer T7601 which produces the Voltage for the LED driver circuit, it also produce the 13VUR.
                                        So you may have bad solder joints on the board or PFC Boosted Voltage drops out. You should have about 400VDC measured between the two legs of either one of the two main filter caps C7800A/B.
                                        You should also look at the DCV of the AC-DET pin to see if it drops down from 3VDC (normal condition should be >3VDC (HI)).
                                        You should also retouch the solders on the transformer legs and the devices mounted on the heatsinks.
                                        • corrize
                                          A funny fuse story – Lumix LX100 II
                                          by corrize
                                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                          10-19-2023, 09:58 AM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
                                        • Loretto
                                          Samsung SMPS BN44-00339A
                                          by Loretto
                                          this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                                          I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                                          I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                                          I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                                          03-29-2025, 08:30 AM
                                        • Loretto
                                          by Loretto
                                          03-28-2025, 10:28 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
