Removing Broken Component Cable Pin
  • kevinm34232
    • May 2012
    • 1884
    I have a main board that has a pin from a component cable broken off inside the port. Any tips on removing this safely?
    • 31015
    Re: Removing Broken Component Cable Pin
    not without a foto
    • kevinm34232
      • May 2012
      • 1884
      OK then...
      • tw2005
        • Oct 2011
        • 6458
        maybe you could get a couple of fine jewellers flat blades either side and lever it up
        or see if that pin will take solder, solder some wire to it and pull it out
        • kevinm34232
          • May 2012
          • 1884
          OK I can try that thx. I don't have the board in front of me but wondering how hard to get to it from underneath.
            • 31015
            show the bottom of the board there - if the solder hole is big enough you may be able to suck the solder out and push a needle up past the solder-pin into the socket.
            • emeskay
              Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
              by emeskay
              We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
              08-06-2024, 07:13 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • Tr0ll
              by Tr0ll
              Original T-con:
              First replacement T-con:
              10-07-2023, 07:48 PM
            • chth96
              Is it possible bridging tiny broken trace
              by chth96
              When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
              cutting tiny trace.
              This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
              Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
              But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
              12-03-2022, 11:32 PM
            • nicktasios
              Macintosh Quadra 840AV PSU
              by nicktasios
              I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
              12-22-2024, 05:07 AM
