Proscan 42LA45H PSU Problem
  • Nr1Ctr
    • Oct 2015
    • 22
    Hello all!
    I've got a Proscan 42LA45H LCD flatscreen that has PSU issues that I'm trying to fix. I looked at the other posts related to this TV and particular board but the problem I'm having seem different. The unit has standby power but will not turn on. This first thing I checked, thanks to you all and others on google, was the caps. I found one that was obviously bad and changed it out. The others looks fine, but I have no way to test them as all I have is a cheap DVM.
    There is also a humming noise coming from the PSU board after I plug it in, and I'm not really sure if it was there before I changed the cap. I checked all the voltages coming off the board and they are as follows:
    gnd - 0
    gnd - 0
    sw - 4.24v
    sw5 - 4.96v
    sw5 - 4.96v
    12/5 - 0.12v
    12/5 - 0.12v
    gnd - 0
    br? - 0
    on - 0
    gnd - 0
    gnd - 0
    m5v - 0.01v
    m5v - 0.01v
    I have attached pictures of the board with the new cap and a pic of what I took to be the bad (old) cap. If anything else is needed please let me know. I'm really just looking for ideas of where to go from here. I got this set for free, courtesy of someone who dropped it off at the dumpster by my place. Figured if I could change a couple caps, or something cheap anyways, it would make a nice Christmas present for the kids. If not, ill just haul it back out there. Thanks all, and I look forward to talking to you.
    edit: Also, I assume that light at VD824 (bottom) is supposed to light up, but it doesn't.
    Re: Proscan 42LA45H PSU Problem
    Can we see the pictures of the whole board, top and bottom side of the board, and also the pictures of the whole back side of the TV so we can see all the boards and how they are connected together?
    Also need the pictures of the connectors so I can see all the pin labels.
    http://www.shopjimmy.com/proscan-114...wer-supply.htm
    • CapLeaker
      Leaking Member
      • 7982
      sounds like your mainboard isn't returning PSon to the power supply. So the power supply doesn't turn on.
        gnd - 0
        gnd - 0
        sw - 4.24v = PS-ON
        sw5 - 4.96v = 5VSTBY
        sw5 - 4.96v[/B] = 5VSTBY
        12/5 - 0.12v = SWITCHED 12V
        gnd - 0
        br? - 0 = DIM CTRL
        on - 0 = BL-ON
        gnd - 0
        gnd - 0
        m5v - 0.01v = SWITCHED 5V
        • Nr1Ctr
          • Oct 2015
          • 22
          More pictures as requested. It'll be a couple hours before I'm back on here. Taking an Assembly Language class (one among many) and I've got a test today. I'll try and check on my phone. Thanks again
          Took me 30 minutes to upload the pics, lol. Hope you don't need many more.
            Thanks for the pictures, I may need more pictures of the bottom side if I cannot trace out the circuits, I'll let you know.
            • Nr1Ctr
              • Oct 2015
              • 22
              Alright then. Back in a bit. Test time..
              • CapLeaker
                Leaking Member
                • 7982
                I guess I better go back to bed.
                • Nr1Ctr
                  • Oct 2015
                  • 22
                  Back now. I like assembly. Only problem is that for every line you write in C++ you have to write 10 (or 100) in assembly. Will be here for a few hours now if anyone has some idea of where I should go from here.
                    OK, I need 4 pictures (1 pictures of large red box, and then 3 sections of the bottom half of the board) total that are clear and without the glare because I cannot easily see the traces. Please do as close focused as you can.
                    • Nr1Ctr
                      • Oct 2015
                      • 22
                      Ok. Will get em first thing in the morning. I can email you the pic from my phone if you want. It's much higher quality and a lot easier to see the traces.
                      • Nr1Ctr
                        • Oct 2015
                        • 22
                        Here's the better pics. I took 4 instead of 3 going across from left to right. And a zoom in of the box you outlined. Hope you can get better visualization. My camera was having a hard time focusing but with more light it gave the glare again.
                        • Nr1Ctr
                          • Oct 2015
                          • 22
                          Are these good or do I need to get clearer ones?
                            I am downloading them right now.
                            • CapLeaker
                              Leaking Member
                              • 7982
                              Originally posted by budm
                              gnd - 0
                              gnd - 0
                              sw - 4.24v = PS-ON
                              gnd - 0
                              br? - 0 = DIM CTRL
                              on - 0 = BL-ON
                              gnd - 0
                              gnd - 0
                              Was sick yesterday
                                OK, please see the attached picture, we will need to get P/N of the M5V switch and the 12/5V SMPS IC, and Voltage at VCC2.
                                Check the DCV on all 3 pins of the M5V switcher.
                                PS-ON is present but it is not turning on the M5V switch and the 12/5 SMPS.
                                • Nr1Ctr
                                  • Oct 2015
                                  • 22
                                  Ok. I will have to figure out how I can hook it up to power and still get access to the back of the board. Will let you know what I find. Thanks again!
                                    At least give us the P/N of those two devices so we can look up the spec sheet for them.
                                    • Nr1Ctr
                                      • Oct 2015
                                      • 22
                                      Here are pics of the two in question. Will get back to you about the voltage soon as I figure out how to get it without zapping myself.
                                      • Nr1Ctr
                                        • Oct 2015
                                        • 22
                                        Does it just need the AC power hooked up or do I have to make sure all the ribbon cables are connected?
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • blind2reply
                                          proscan 40ld45q - no pic -no sound - no backlight - blue light turns off
                                          by blind2reply
                                          proscan 40ld45q
                                          Have tried published resets with no help. (unplug for 10, push on-off for 30, push menu and vol +, etc.)
                                          After being plugged in, red light comes on. Push power button and blue light comes on for ~five seconds then goes out. Power button does not turn the unit on a second time - have to unplug/re-plug before power button will try to start with blue light.
                                          No sound, no picture (used flashlight test).
                                          No bulging cap, no burn spots, no burn smells, nothing visual (cold joints/breaks/bugs).
                                          Digital voltmeter;...
                                          06-06-2021, 01:16 PM
                                        • birdboy385
                                          Proscan 50" PLCD5092a-b Restarting
                                          by birdboy385
                                          Hi all, I have the aforementioned Proscan television. Basically what happens is the TV will boot up like normal once you push the power button, the Proscan logo shows then it shows the channel select and almost immediately you see the date in the corner reset ( I can't recall what to but I semi assume it doesn't matter).
                                          The TV then freezes for a few moments then restarts. The Proscan logo shows up and the cycle continues pretty much indefinitely. I haven't attempted to let it sit for long to see if it would ever stop doing it. Once the Tv boots up, attempting to push any buttons...
                                          02-13-2019, 10:33 AM
                                        • lapfix
                                          Dell Latitude E5550 LA-A911P no complete power on !
                                          by lapfix
                                          First the lap come witth a short to GND , it was a faulty capacitator : PC716
                                          After desoldered , the lap works fine...but after some tries not power on.
                                          Power supply reach 0.159amp for 1 minute than off...no short to GND at all coils .
                                          All the voltages at PM TABLE are finded , try another bios same behaviour !
                                          PS id is oK ; i try with an original charger same behaviour too...
                                          PQ700 a P-channel is ok , but his gate is not correct..0.001v...
                                          Pin 5/8 = 19v
                                          Pin1/3 = 19 v
                                          Pin 4 = 0.001v...not correct.
                                          Pu 800 =
                                          Pin...
                                          07-29-2024, 06:05 AM
                                        • shelby5041
                                          Proscan 40LD45Q messed up and no image
                                          by shelby5041
                                          hi
                                          tv powers on fine to a blue screen
                                          when OSD is hit the menu shows up ok sometimes for a few seconds and then just slowly fades away..if i click a diff menu option the refresh is lagging big time from option to option...
                                          backlights are fine
                                          this is one of those funky issues that im not sure what would be the cause..maybe bad lcd panel bonded tabs?
                                          09-22-2020, 03:18 PM
