Proscan 50" PLCD5092a-b Restarting
  • birdboy385
    • Nov 2015
    • 145
    Hi all, I have the aforementioned Proscan television. Basically what happens is the TV will boot up like normal once you push the power button, the Proscan logo shows then it shows the channel select and almost immediately you see the date in the corner reset ( I can't recall what to but I semi assume it doesn't matter).
    The TV then freezes for a few moments then restarts. The Proscan logo shows up and the cycle continues pretty much indefinitely. I haven't attempted to let it sit for long to see if it would ever stop doing it. Once the Tv boots up, attempting to push any buttons on the TV has no effect at all. My initial thought was a problem with the EEPROM since I had similar symptoms with another TV.
    I was able to "resolve" the problem by freezing the EEProm chip which was suggested on the forums. I attempted the same thing on this one with no luck. Obviously that doesn't rule out the EEPROM as the problem but my gut tells me it's at least something to do with the Mainboard and not the Powerboard. I would think the buttons would still respond if it were the power board.
    I can get pictures within the next day or so because I'm sure that will be important and I wish I got them when I was doing the freeze trick. Other than getting the pictures, does anyone have any other suggestions on what to look for for testing or a good idea of what's wrong? I do see EEPROM replacements are a common part on sites such as Amazon and ShopJimmy. That was also what led me to hypothesize the problem.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8225
    Re: Proscan 50" PLCD5092a-b Restarting
    Unfortunately the freeze the EEPROM trick doesn't work 100%. The only way to really know, is to take the EEPROM off the board, read and store the contents, then write it full with FF's. Then read or blank check the EEPROM again.
    Did you try to update the firmware on this TV yet?
    • birdboy385
      • Nov 2015
      • 145
      "Unfortunately the freeze the EEPROM trick doesn't work 100%. The only way to really know, is to take the EEPROM off the board, read and store the contents, then write it full with FF's. Then read or blank check the EEPROM again."
      Yeah, I unfortunately do not have an EEPROM tool at my disposal.
      I have not. I could definitely look into how it's done on this TV. I know with most of the ones I've seen, you have to boot the TV then go into a service menu by accessing the normal menu. If that's the case then it will be impossible since I have no normal access to functions.
      • Unspun01
        • Jun 2011
        • 349
        Birdboy:
        RCA and Proscan are very similar TVs.
        I have a 32" RCA LED TV (RLED3216A) with same issue. TV turns on, displays the RCA logo, then screen flashes entirely green for a split second, then clearly shows the channel number in upper corner, then resets itself.
        Heating or Freeze spray did not work on this TV EEPROM. Same issue.
        Reading the EEPROM and reprogramming to a new EEPROM chip did not fix the TV since the EEPROM contents are damaged.
        For testing, I programmed an EEPROM from a different but similar 32" LED TV and the TV sort of works with upside down image and all the buttons are re-mapped but the resetting problem goes away.
        ***********The problem is definitely EEPROM**********
        I need the proper EEPROM .BIN file to correctly fix my TV. I suspect you will also need to find a suitable EEPROM. BIN file to reprogram the chip, or replace the mainboard.
        Can you post a few clear images of your mainboard? and the model number of the actual panel installed in this TV perhaps someone can provide a EEPROM firmware that may work for that combination of mainboard and panel.
        (On another note, I tried to figure out the bad area of the EEPROM by viewing it in a HEX editor and I tried splicing some info from a different EEPROM .BIN file, but I had no success)... I may try CAPLEAKER's suggestion of writing 00 or FF to the original EEPROM IC to see if I can locate the bad sectors and see if I can "create" a firmware.
        • birdboy385
          • Nov 2015
          • 145
          Sorry everyone, I hopped off this project for a while. So it seems I have two options, get an EEProm tool and put a new eeprom on the existing board, or just get a replacement main board. I imagine the price point for the tool and part will be relatively similar compared to just buying a mainboard on the cheaper end. I think it makes sense just to buy a replacement mainboard.
          • R_J
            • Jun 2012
            • 9559
            The CH341 usb programer will work, likely set you back about $10.00, eeprom another couple bucks
            • dmccul2698
              Pioneer DEX-P99rs "No EEProm " diagnostic code.
              by dmccul2698
              Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
              1). Understand the schematic and check the connections between the EEProm and DSP
              2). Check the functionality of the EEProm
              I don't know if this is the unit's problem but it's a place to start.
              I have little to no electronic experience...
              04-08-2024, 05:32 PM
            • edgarmg15
              Damaged EEPROM on TV Vizio E320-A0
              by edgarmg15
              Hi everyone
              I´m trying to repair a TV Vizio E320-A0 that I found in the street
              The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
              The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
              So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
              11-19-2022, 03:46 PM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • SidneyCanadas
              93C46 and 93C56 EEPROM
              by SidneyCanadas
              I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
              https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
              Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
              06-14-2023, 01:16 PM
            • AlexGsmMaster
              Eizo CS2740 eeprom dump, search.
              by AlexGsmMaster
              Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
              07-26-2025, 03:24 PM
