Still clicking after replacing eeprom Samsung LE40M87BDX
  • lin4sm
    • Sep 2011
    • 67
    As I have said in title TV relay is clicking.
    Opened back, someone have tried to resolder caps on BN44-00167A power supply board. So I have just installed known good BN44-00167A board and TV still clicking. Then taken out BN41-00813E mainboard and replaced eeprom with blank chip. Installed back to TV. 1 click and after 15 seconds back into usual clicking.
    Where is a problem, I have already 2nd mainboard exactly the same?
    First photo original eeprom
    Second photo empty eeprom
    Third photo BN41-00813E Bottom
    Fourth photo BN41-00813E Top
    Am I doing something wrong?
  • finntricky
    • Jan 2014
    • 449
    • uk
    Re: Still clicking after replacing eeprom Samsung LE40M87BDX
    i have had a problem with these model tvs not turning on, and found though this forum that there are 2 SM caps under the shield on the main board that needed replaceing,
    think it was 100uf, tv is now fine with no probs.
    • lin4sm
      • Sep 2011
      • 67
      I will try to remove shield. Will check caps this evening. Are you talking about those bigger ones next to BGA chip?
      • finntricky
        • Jan 2014
        • 449
        • uk
        yes, just replace them 2, thay are a bit of a prob to remove so be carefull, i have pulled the tabs before,
        i replaced with normal caps and layed them down so the shield would still fit
        • lin4sm
          • Sep 2011
          • 67
          Finally I have manage to remove cover. Removed caps. I imagine they are 10V 1000uf. One measuring 960uf the other one measuring 910uf. I will try to replace them.
          I am wondering could I try mainboard without metal cover? I know that this is as heat sink, but how hot are those two BGA chips?
            Are you sure they are 1000uF, that will be quite big in dimensions?
            • lin4sm
              • Sep 2011
              • 67
              I have removed two big caps underneath of cover on top of them says V0012 1000 10T. I imagine this is 10V 1000uf capacitor see photo. The other photo of the space where metal cover was. I have highlighted places with red cross where capacitors were.
              Unless I have removed wrong ones. There are only one that looks like 100uf, one is 47uf and others are 82uf.
                They look big so you probably correct that they are 1000uF (some cap companies will use 1001 = 1000uF), 101 = 100uF, 100 = 10uF) since you verify with cap meter.
                They are part of switching power supply. Do you have ESR meter?
                Did you also try heating up that section under the shield to see if the TV will function mormally?
                • steviewonder
                  • Dec 2013
                  • 183
                  • england
                  yes,those caps are quite often faulty.Another problem that can also arise with those is a loud crackling through the speakers as it tries to start up.
                  Becoming increasingly common,it also seems the solder cracks underneath the dtv processing ic,also under the screening tin,causing the same issue of clicking,usually as the set is warming up.
                  • lin4sm
                    • Sep 2011
                    • 67
                    OK. I will head back to my workshop and I will try to replace those capacitors as one is on the lower side.
                    I do not have ESR meter. Will put in "to buy" list.
                    • lin4sm
                      • Sep 2011
                      • 67
                      Update. Replaced those two capacitors with 10V 1000uf. TV turns on. No clicking. Will do more testing now.
                        Great! The old caps are still within 20% tolerance so they probably have high ESR.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Nice one thanks for the info
                          • lin4sm
                            • Sep 2011
                            • 67
                            Replaced capacitors for the second exactly same mainboard with the same symptoms. It started working too. Capacitance were good, most probably ESR out of range too
                            Will do further testing and will update later on.
                            • finntricky
                              • Jan 2014
                              • 449
                              • uk
                              yes your right, 1000uf ones, glad to see my input was usefull
                              • lin4sm
                                • Sep 2011
                                • 67
                                finntricky, thanks for guidance.
                                Thanks everyone for helping to sort out this problem.
                                TV is running few hours without problem now. Will check in the morning for cold start, but I think it should be OK.
                                • lin4sm
                                  • Sep 2011
                                  • 67
                                  This morning I am turning TV and it is working!
                                  Thank you everyone for your input, problem solved!
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    I'm wondering, this can be the case on newer TVs as well, where there are no big capacitors on the board?
                                    I have a clicking UN40C6300.
                                    • lin4sm
                                      • Sep 2011
                                      • 67
                                      I have UE40C6505UK sitting in a corner with bad main board. BN41-01444B BN94-03588P this main board forces power supply relay do clicking noise. Biggest problem there are only SMD components and few BGA chips. At the moment I do not have spare time to try to trace what is wrong with it. If someone would give a clue would be great.
                                      • daveb9999
                                        • Mar 2017
                                        • england
                                        excellent advice after endless hours of searching and research it worked perfect on 3 sets thank you
                                        • SidneyCanadas
                                          93C46 and 93C56 EEPROM
                                          by SidneyCanadas
                                          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                                          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                                          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                                          06-14-2023, 01:16 PM
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          Today, 02:18 PM
                                        • dmccul2698
                                          Pioneer DEX-P99rs "No EEProm " diagnostic code.
                                          by dmccul2698
                                          Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
                                          1). Understand the schematic and check the connections between the EEProm and DSP
                                          2). Check the functionality of the EEProm
                                          I don't know if this is the unit's problem but it's a place to start.
                                          I have little to no electronic experience...
                                          04-08-2024, 05:32 PM
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • edgarmg15
                                          Damaged EEPROM on TV Vizio E320-A0
                                          by edgarmg15
                                          Hi everyone
                                          I´m trying to repair a TV Vizio E320-A0 that I found in the street
                                          The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
                                          The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
                                          So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
                                          11-19-2022, 03:46 PM
