Led back light
  • Rickig
    • Mar 2015
    • 112
    • England
    Led back light
    Hi I have a back lit led tv that I suspect a led has gone down as the backlight no longer illuminates
    My question is what s a safe voltage to put across each led to test it and when I find it what size resistor would be best to solder in its place to bypass that led.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Led back light
    2.2k ohm resistor or 3w zener diode in reverse bias to bridge over the Led. To check each led you can use your Dmm put the probes on the respective polarity of the Led and if its good it should slightly illuminate.
    • Rickig
      • Mar 2015
      • 112
      • England
      Re: Led back light
      And if it doesn't?
      • steviewonder
        • Dec 2013
        • 183
        • england
        Re: Led back light
        then the LED is duff..a 3v supply to each individual diode should provide illumination.
        Often,the led itself is visually burnt.
        Good luck!
        • flocko
          • Nov 2012
          • 1121
          • uk
          Re: Led back light
          LEDs will be open, short or working, if its short your meter will show this, if it is open it will show that also, and if it glows its working. You fail to tell use the make and model number of the set you are trying to fix? not all LEDs are the same voltage ?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Re: Led back light
            Originally posted by Rickig
            And if it doesn't?
            Well if it doesn't light what is it ? Dead !
            • retiredcaps
              • Apr 2010
              • 9271
              Re: Led back light
              Be aware that multimeters vary greatly in the output voltage when in diode mode. For example, the Fluke 87V will output more than 7V in diode mode. I have a Brymen meter that only outputs 1.5V in diode mode.
              --- begin sig file ---
              --- end sig file ---
              • Rickig
                • Mar 2015
                • 112
                • England
                Re: Led back light
                That's what I was referring to... What if the meter doesn't output enough voltage to illuminate it. So 3v should be ok?
                Bush bmk40
                  Re: Led back light
                  You should put the current limiter resistor in series with the power source when you try to test the LED.
                  http://led.linear1.org/why-do-i-need...r-with-an-led/
                  https://www.sparkfun.com/tutorials/219
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Re: Led back light
                    The meter will have enough juice to dimly illuminate the leds.
                      • 31294
                      Re: Led back light
                      i test led's with an old coincell from a motherboard - i have lot's of used ones.
                      • Rickig
                        • Mar 2015
                        • 112
                        • England
                        Re: Led back light
                        Ok I will check them all and when I find the bad one I just solder the traitor in its place and it should resume normal function? Minus some brightness of course
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Re: Led back light
                          It wont be too noticeable the brightness difference and what do you mean by traitor ?
                          • Rickig
                            • Mar 2015
                            • 112
                            • England
                            Re: Led back light
                            The meter didn't power them had to use a battery. Have 6 LEDs out. 8 strips of 5 led and 3 on 2 strips gone. I've removed the bad ones... Any idea where a can get replacements?
                            Spell check -- traitor = resistor
                            • Rickig
                              • Mar 2015
                              • 112
                              • England
                              Re: Led back light
                              http://www.maplin.co.uk/p/3w-high-power-white-led-n79jq
                              Will these do?
                                Re: Led back light
                                That is really big because it is 3W, you need the dimension of the old LED and the solder pads, 1W should be OK to use.
                                What does the one in the panel look like?
                                • Rickig
                                  • Mar 2015
                                  • 112
                                  • England
                                  Re: Led back light
                                  http://www.maplin.co.uk/p/white-led-n67jq
                                  These?
                                  My board has 5 LEDs and says vf max 18v so I assume each led is 3.8v Ish?
                                  Says if= 320ma the above is if 350ma. That ok?
                                    Re: Led back light
                                    These?
                                    So the LED strip has all that info printed on it, 18V MAX, If = 320mA? 18V/5 LEDS = 3.6V
                                    So you will be running at lower current which will be fine, I also doubt that they are running them at MAX If.
                                    • Rickig
                                      • Mar 2015
                                      • 112
                                      • England
                                      Re: Led back light
                                      Yes says that on it.
                                      Original is if320
                                      The maplins are 350 that OK?
                                      I noticed on maplins page it says heat sink required..... Will I really need that's?
                                        Re: Led back light
                                        "The maplins are 350 that OK?' yes, you are going to be running at the lower current, but I do not know if it will have color shift at lower current drive or not. The existing strip is probably using the copper pads for heatsink, so if this LED should be able to handle it, we still do not know what your LED strip look like, the original probably does not have good thermal management either so they burn out.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • PNI E.
                                          tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                          by PNI E.
                                          hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                          02-20-2025, 08:36 AM
                                        • koby058
                                          vostro comes up with back light but no picture
                                          by koby058
                                          Hi people!!
                                          The owner said it showed bad picture once in a while (attached)
                                          I see that there is back light but no picture.
                                          I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                          Also attached schematic and BDV
                                          LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                          07-13-2025, 01:03 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
