Sharp LC-40LE550U no backlight
    Re: Sharp LC-40LE550U no backlight
    The 0.89V is the Vf of the protection diode not the White LED Vf, you need to reverse the probes to read the Vf of the LED which it should be around 2.8- 3V.
    It can also be that your meter does not put out enough Voltage in Diode mode to turn on the White LED.
    It can also be dual LED in one body so the Vf will be around 6V.
    • Markpixley
      • Aug 2012
      • 37
      Thanks for the response, so down that road would it be about as smart to make a simple power supply and test each LED since I have already scratched the surface to diode test them? Just do the 3 volt test and see if they light?
      It seems odd to me that there are 5 distinct strips and 10 power leads, if a single led was out wouldn't that simply stop that strip from working instead of all five strips?
      I am not techy enough but trying...(I actually build vintage tube recording gear so this lower power stuff is all new to me)
        If you look at the LED connectors in deatails, you can see that the LED strips are connected in series to form ONE long LED string, if ypu look at the bottom side of the power supply board where the LED connector CN202 PIN 1 (+) is connected to the LED power supply filter cap CL115 positive leg, the pin 1 of CN202 goes to the first LED string ANODE, the negative return goes to CN202 PIN 2 (-) this (-) is then connected to the Anode (CN202 pin 3) of next LED string, and on and on to the fifth string.
        So as you can see, the LED connectors are terminated as series connections for the 5 LED strings, if one goes open circuit then the whole backlights will not be on.
        Pictures provided by shopjimmy.
        Sharp 9JY0940CTJ05000 (FTPL-009) Power Supply Unit.
        http://www.shopjimmy.com/sharp-9jy09...pply-unit.htm#
        • Markpixley
          • Aug 2012
          • 37
          Ahhh very helpful again it takes some of the voodoo out of it...making moire sense Thanks!
          • Markpixley
            • Aug 2012
            • 37
            Originally posted by Markpixley
            I also have another question since i have never seen these before, but what is the clear diode looking fuse item labelled SG105 in the bottom right hand corner of image #2?
            Is it some sort of slow blow fuse and if so is there a way to test it? It seems to connect ground planes on the back of the psu...but I am unfamiliar with it.
            All the other "SG" parts show a continuity test beep, EXCEPT this one in the corner...is this some kind of time delay fuse or capacitor part?
            This one is not giving me any response, Ohm or continuity at all...
            Does "SG" mean surge guard?
              Surge Arrestor, as you can see, some of them are connected in parallel with the inductor windings so you see very low DCR.
              • Markpixley
                • Aug 2012
                • 37
                Thanks budm, you have been very helpful...
                So here's where I am at...I used a 12 volt psu and tested all the LED's (based on your suggestion that they are double and 6 volts)...every pair I tested lite up brightly and all my continuity test on the strips seem to be solid...
                Unit power light turns green...I can get it to turn red but it takes a bit...and it usually just flips back to green...
                No back light...at all voltages still as earlier...
                Without being to much of a bother what might be my next course of testing?
                  So you can light up each LED strip individually using external power supply.
                  You have 5 LED strips, each strip has 10 LEDs, each LED is rated at 6V, so total Vf is 50 LEDs x 6V = 300V, and you have 329V feeding the strings per post #1 but you never see the LEDs light up at all.
                  It means you have open connection between the 5 set of the LED strings some where, or the LED return through the Power MOSFET is not active.
                    What DCV do you have on pin 5 of CN203, that the LED string return line to the PWM Controlled power MOSFET QD101?
                    • Markpixley
                      • Aug 2012
                      • 37
                      76.2 vdc
                        BTW, what is the P/N of the LED backlights controller IC UD101?
                        • Markpixley
                          • Aug 2012
                          • 37
                          the voltage to Cn202/cn203=
                          1. (+) 340
                          2. (-) 286
                          3. (+) 286
                          4. (-) 233
                          5. (-) 233
                          1. (-) 180
                          2. (+) 180
                          3. (-) 128
                          4 (+) 128
                          5. (-) 77.8
                          • Markpixley
                            • Aug 2012
                            • 37
                            Nikos
                            PO425AD
                            WUE900302
                              76.2 vdc
                              OK, so there is no open connection on the LED strings, and you can get all the LEDs in each strip to light up OK.
                              • Markpixley
                                • Aug 2012
                                • 37
                                Correct...now here's a question...
                                The Rich Tek chip (UD101)
                                Pins 13/12 each show 10 volts (led 1/2)
                                Pins 10/9 show no voltage (.004) which would be led 4/3
                                Vin is 12v
                                Fault is 12v
                                Is this chip ONLY being used for two led diagnostics? and pins 10/9 would never be used anyway?
                                • Markpixley
                                  • Aug 2012
                                  • 37
                                  Forgive me for being dense (Thick as a brick per Jethro Tull)...
                                  I start with 340 volts and end with 76 but no light...so where in hell is all that voltage going?...if it was open I would not see any voltage at the last pin...
                                  If there is a short...?
                                    1. (+) 340
                                    2. (-) 286
                                    3. (+) 286
                                    4. (-) 233
                                    5. (-) 233
                                    1. (-) 180
                                    2. (+) 180
                                    3. (-) 128
                                    4 (+) 128
                                    5. (-) 77.8
                                    Looking at those reading for the Vf of each string, for example: the first string is 340 - 286 = 54V, so average Vf of each sting is about 52V which is not right since ten 6V LED should be 60V per string.
                                    It looks like the MOSFET QD101 is not being turned on.
                                    I need to look up the spec the IC UD101 to see how it function.
                                    • Markpixley
                                      • Aug 2012
                                      • 37
                                      So far the info I have gathered on the niko is it is not schothy or esr, it can maintain up to 800 rds volts on 10v...seems like it goes up to 4 amps 512 pf Ciss typical...
                                      • Markpixley
                                        • Aug 2012
                                        • 37
                                        Yes its actually a little more each string has eleven led's so the voltage required is 66volts...
                                        • Markpixley
                                          • Aug 2012
                                          • 37
                                          I flipped the psu over and have it plugged in, powered up and the Mosfet QD101 reads 12.44v bottom leg at left, 14.17v bottom leg right (same as pin 13 on UD101) and 79.2v (same as Cn203 pin 5/bottom rail of led return)
                                          • Superbee_dad
                                            Sharp 80” long short flash backlight error - Help
                                            by Superbee_dad
                                            Hello Sharp TV experts
                                            Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                            > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                            > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                            01-24-2025, 11:51 PM
                                          • Misterfixit
                                            Sharp LC-58Q7330U No Backlight
                                            by Misterfixit
                                            This set has the known reputation of failed led backlights. The set does not turn on, but when plugged in, the power led stays lit for about 5 seconds followed by two short blinks and then it repeats itself. While shinning a flashlight on the screen, you can make out the Sharp logo, then it goes out and repeats the cycle. I measured some voltages across the led backlight connector. What has me puzzled is that when I place the negative lead of my vom on the led backlight pin connector (in which the black wire going to the leds was), I measure as high as -228volts, and then it falls to -95 volts...
                                            06-04-2023, 07:39 PM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • Misterfixit
                                            sharp LC-50LB601U No backlight
                                            by Misterfixit
                                            I have a sharp LC-50LB601U that has no backlight. It starts up fine, and has sound, however, I can only see the screen using a flashlight. I took the tv back off and measured voltages at the power supply connector CN-8601. As you can see by the picture, the led connector has 2 sets of 2 red wires and 2 sets of black wires going to the led backlights. Between each set of black wires and corresponding red wires, I measure 30 volts (pins 1 and 4) and 30 volts from pins 8 and 12. From ground to each set of red wires ( pins 1 and 12 to ground), I measure 35 volts. This voltage seems very low compared...
                                            04-04-2023, 01:21 PM
                                          • DanPoka
                                            Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                            by DanPoka
                                            I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                            Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                            This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                            02-15-2025, 05:05 AM
