Technika LCD22-228G 21.6" Flatscreen TV - Resetting after a few seconds
  • Ken Laszlo
    • Sep 2015
    • 28
    Hello everyone
    I hope you guys can help me with my current repair of this Technika (yes, I know!) flatscreen 21.6" TV with in-built DVD. Crappy Tesco purchase.
    (Please see attached photo).
    Symptoms
    The unit resets itself after a random amount of seconds back to standby mode and then attempts to fire back up again. There is no pattern to it - Generally it never stays on for more than 15 seconds.
    The backlight is fine and 'No signal' is often displayed on the screen for a short time.
    Checked so far
    The board in the centre is the Power supply (which outputs a single 12V rail). This unit is working fine. I changed the two 1000uF capacitors anyway, but this board is not the issue as I confirmed that the unit still resets itself when using a totally different 12V power unit.
    The problem appears to be the main board on the left.
    All capacitors seem fine, although I did change several 470uF caps which were across the 12V rail anyway to see if it helped (no change).
    Right now, I am stuck. There are more capacitors on this board that I could change (most 470uF) but they look fine. I've heard bandied about that it may be an issue with a regulator but I'm not certain. I don't have access to a scope, just a Digital meter. For reference, the caps on the board are marked as make SGF (not heard of that one).
    Any assistance you guys can provide would be gratefully appreciated.
    Thank you
    Chris
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Technika LCD22-228G 21.6" Flatscreen TV - Resetting after a few seconds
    This could be a faulty eeprom what is the mainboard number.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      I would say epprom as well being a CV mobo seen lots of them fail.
        • 31068
        i'v got one of those.
        has anybody got a spare stand?
        btw, check the 5v on the mainboard - make sure it's not dropping out.
        and dont confuse it with a seperate 5v supply for the dvd drive.
        • Ken Laszlo
          • Sep 2015
          • 28
          You guys are great - Thank you for all the speedy responses.
          Mainboard reads thus:
          Model: X185/54G-GB-TCDU-UK
          ATV: CV306L-F30_LTM185/LTA216AT01-B1.2.14-5C30
          The TV is model number:
          Cheers
          • Ken Laszlo
            • Sep 2015
            • 28
            Stj - Yes, I see there are two separate 5V regulators on that board.
            I can check them tomorrow.
            • zklgfs
              Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
              by zklgfs
              I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
              08-11-2025, 02:14 PM
            • twonk9098
              Lenovo Legion 5 high fan spin turns off after 34 seconds
              by twonk9098
              I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
              I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
              I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
              I have tried a few new bios but exactly...
              07-14-2024, 11:19 AM
            • ngml
              Repair of an LG split AC system indoor unit PCB
              by ngml
              I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
              This indicates an error in the communication between the outdoor and the indoor unit.
              The outdoor unit is fine, so the problem is the indoor PCB.
              The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
              I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
              Does anybody have the schematics of this board,...
              02-01-2025, 12:55 PM
            • nobbnobb1
              Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
              by nobbnobb1
              Hi guys,
              Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
              When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
              02-03-2022, 11:14 AM
            • liquidzorch
              Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
              by liquidzorch
              Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
              10-18-2024, 05:19 PM
