37lg7000 sound. No picture but backlight on.
  • Rickig
    • Mar 2015
    • 112
    • England
    Re: 37lg7000 sound. No picture but backlight on.
    Vgl -8v
    Vgh 24v
    • Hamie
      • Apr 2014
      • 1383
      invalid, deleted.
      • Rickig
        • Mar 2015
        • 112
        • England
        Just done that. the readings are as above
        • Hamie
          • Apr 2014
          • 1383
          Ok so far the voltages appear accurate.
          • Rickig
            • Mar 2015
            • 112
            • England
            So what's the verdict? Does that mean tcon good?
            • Hamie
              • Apr 2014
              • 1383
              Finally check the gamma test points.
              Located here, and also to the left (the ones under the white line you were testing previously.)
              22 in total, post back results like:
              V1-
              V2-
              V3-
              Etc
              • Rickig
                • Mar 2015
                • 112
                • England
                #27
                V1 16.5v
                V2 16.2 v
                V3 14.4v
                V4 13.6v
                V5 5mv
                V6 12.6v
                V7 23mv
                V8 11.5v
                V9 10.7v
                V10 8.7v
                V11 8.7v
                V12 8.3v
                V13 8.3v
                V14 6.3v
                V15 5.5v
                V16 27mv
                V17 4.3v
                V18 27mv
                V19 3.2v
                V20 2.5v
                V21 0.6v
                V22 284mv
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #28
                  thers some odd readings there never saw any mv before
                  • Hamie
                    • Apr 2014
                    • 1383
                    V10 - V13 don't look right either.
                    • Rickig
                      • Mar 2015
                      • 112
                      • England
                      #30
                      Def mv.
                      So what's the next move?
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #31
                        some maybe mv im still learning myself but have never saw any threads with mv in the gamma readings im sure someone will comfirm later maybe tom or budm will have a idea if hamie isnt sure?
                        • Hamie
                          • Apr 2014
                          • 1383
                          In my experience the voltages should drop gradually.
                          So if those readings are correct you have have a faulty t-con.
                          Going by the fact I can't seem to find anyone selling one would usually suggest that this board has quite a high failure rate.
                          • Rickig
                            • Mar 2015
                            • 112
                            • England
                            #33
                            Double checked all mv ones and they are all in the mv range. So shall I be looking for a tcon?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #34
                              If this was my set the tcon is usually the cheapest of the boards so yes i would probably change it. Make sure you get one with a returns policy just incase its faulty already failing that you may have to look for a smashed screen working set and use the boards from that.
                              • CapLeaker
                                Leaking Member
                                • 8326
                                Not really sure what to say. Gamma readings are there, also they are bad, but that shouldn't cause a no picture, bad gamma just causes a bad solarized pic. Would be nice checking the lvds cables in and out of the Tcon..
                                • Rickig
                                  • Mar 2015
                                  • 112
                                  • England
                                  #36
                                  So if the readings are good and screen is blank can I assume the main isn't sending any graphics out?
                                  • CapLeaker
                                    Leaking Member
                                    • 8326
                                    The gamma readings aren't good, but they are there. That shouldn't cause a black screen. Yes and no, that's why I suggested to use the oscilloscope on the LVDS first place. That's the only 100% way I know how to check a main or Tcon for video. I usually don't bother checking the gamma unless I have trouble with the gamma. More important to have video on the screen first place.
                                    Last idea I have is that you check each lvds output on the main and the Tcon. You would have to measure each LVDS channel pair for 350mV with your DMM. So far you still don't know yet, if you actually have any video coming from the main board or not.
                                    • Rickig
                                      • Mar 2015
                                      • 112
                                      • England
                                      #38
                                      Hmm. Think I'll order a tcon and try.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        #39
                                        Quote ! Last idea I have is that you check each lvds output on the main and the Tcon. You would have to measure each LVDS channel pair for 350mV with your DMM. So far you still don't know yet, if you actually have any video coming from the main board or not.
                                        capleaker is this easy to do and easy to find the channel pairs? do you just test across the pairs?
                                        • Hamie
                                          • Apr 2014
                                          • 1383
                                          Bad gamma can cause many faults.
                                          Solarisation being one of them.
                                          Image to dark, image too light etc.
                                          I had one fairly recently where the image started off a bit dark then faded out to to completely black.
                                          Therefore with gamma voltages as bad as the ops I'd be surprised if it wasn't caused by the tcon.
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • triplefour
                                            by triplefour
                                            09-13-2023, 10:43 PM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • DKWS89
                                            Sony XBR 49x900E - Sound and backlight on but no picture
                                            by DKWS89
                                            Hey Guys,
                                            So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                            All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                            12-14-2023, 04:30 PM
