I am able to turn this unit on and it stays on. However, I am not getting any Blink Codes (power LED nor OPC) The power LED stays green but I have no picture. Any troubleshooting info would be greatly appreciated. Thanks. Also I have removed the main power board and did a visual inspection. Did not find anything. Also did the channel up vol down trick with same result. No difference doing that or just hitting the power button.
Sharp LC-C5255U No Blink Codes only Black Screen
Re: Sharp LC-C5255U No Blink Codes only Black Screen
No pictures on the screen but you do have backlights?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
No backlights that I can tell. I did however revisit the trouble codes on the tv. Evidently I never left it powered up long enough to get codes. I now get both the power and OPC leds flashing twice together and then the power LED flashes one additional time and then the cycle repeats.Comment
Service manual may be close enough for the error codes:
https://docs.google.com/file/d/0B3xF...YkU/edit?pli=1
Pictures of the whole back side of the TV will help.
Lots of boards used in the same model as your and in LC52SB55U.
This was posted by budm in another thread but the same tv as yours.
also found this that may help
https://www.badcaps.net/forum/showth...harp+LC-C5255ULast edited by vinceroger69; 09-28-2015, 07:22 AM.Comment
Here are excerpts from the Sharp Service manual concerning the LED/OPC codes. Also I'll take full pics later tonight of the main board and post tomorrow.
According to the manual (assuming I am reading it right) my codes are:
Power LED flashes 3 times. Communication failure with main CPU. See Codes and Codes3
OPC LED flashes 2 times. DET_D3V3 failure. D3.3V not applied at CPU (pin 36) See Codes 2.Comment
Maybe budm will have a idea what too check next as he was helping in the thread i posted in post 4.Comment
Wasn't able to take images. camera was dead. phone camera images were not good enough to see the detail required. have a new battery charged and ready. Also after reading the previous posts from jkmorek about a similar issue I am going to work through those steps and add the results here along with the board images.Comment
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by EazyBoneAnother TV topic!!
I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?... -
by Mad_ScienceI have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
03-01-2024, 05:05 PM -
by scubacamperI found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display... -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... - Loading...
