Sony KDL-46EX500
  • dhoff024
    • Mar 2013
    • 96
    Sony KDL-46EX500
    I have a friend that brought me this TV and asked if I could fix it so I told him that I would try since I have fixed a few TV's with the help of the forum. Basically what is going on is the TV when plugged in the red power light is on. After you press the power button the light turns green and the TV makes a chiming sound 2 times probably about 15-20 seconds apart. After that the TV shuts itself off. The screen remains black and doesn't really do anything that I can see. I did take the back off but did not see anything out of order all the caps look good and didn't notice anything alarming but I did take some pictures of the boards to see if there is something I am missing or something that I don't know of that I should check.
  • aaronwt6
    • Apr 2013
    • 855
    • US
    Re: Sony KDL-46EX500
    Well, without any further testing I can tell you from personal experience that it's almost certainly a main board issue. I've dealt with quite a few 32, 40, and 46 EX300, EX400, and EX500 series Sony's. My basic finding on them as been that if they are completely dead with no lights or response it's the power supply, and if they are doing the multiple startup scenario you are describing, it's the main board.
    Check all your voltages on the supply while it's attempting to start. Most likely, they come up until the TV shuts back down.
    • dhoff024
      • Mar 2013
      • 96
      Thanks for the reply I will check the voltage when I get a chance so basically if voltage is ok until the TV shuts off its the main board? Also if the main board is the issue is the only solution purchasing a new board?
      • CapLeaker
        Leaking Member
        • 8352
        Check the BLon (backlight) pin on the PSU. Does the backlight come on at all (maybe for a second or 2)? Check the main filter cap for >360VDC when the tv is on. Also do the flashlight trick on the screen if you do see a picture.
        Also post a straight shot of the PSU with the pin out (top left).
        • dhoff024
          • Mar 2013
          • 96
          Just replaced the main board on the TV today and still getting the same issue any other suggestions? I tried the flashlight trick and got nothing so there the backlight I believe is fine. With this mainboard I am getting the red light blinking 6 times when the TV is plugged in but off.
          • dhoff024
            • Mar 2013
            • 96
            Also this time the startup scenario it chimes 3 times instead of 2 times like it did before. I am not sure what the names of each of the boards on the TV are. Obviously I know the main board but what are the names of the other boards and where else should I check. Most other TV's that I have fixed have been cap issues or something where I could pinpoint the problem and replace parts I have never had to us a DMM and check voltage and don't really know where to start if someone could help me with how to begin and where to start with this TV to try to track down the route of the problem I would appreciate it.
            • budwich
              • Jul 2015
              • 3097
              no sure how to read this as there appears to be some words missing.... "I tried the flashlight trick and got nothing so there the backlight I believe is fine". Is there or isn't there any backlight happening... ever? My "read" would be that you have a backlight issue somewhere.
              check fusing on the inverter board.
              • dhoff024
                • Mar 2013
                • 96
                Sorry for the confusion I posted this a while ago and I didn't have access to the TV again to look at it since it is a friends and not mine. I told him that it was a possible main board issue that he could order the board or I would have to look at it further it was up to him so he ordered the board and I just got a chance to go replace the board but that did not work. There was a previous suggestion of trying the flashlight trick to see if I could see picture. I tried the flashlight trick but there is nothing.
                So what is going on is when I first got to look at the TV when you turned it on the green light would come up and flash and the TV would chime twice about 20 seconds apart and then shut down and the red light would blink. There was never any signs of the backlight. My friend bought a new mainboard and I replaced it now I am getting the same symptoms but it will chime 3 times at startup instead of 2 but there is still no backlight and the TV will shut down after the 3rd chime and the red light blinks 6 times.
                I would like to think of myself as pretty mechanically minded and with direction I can usually fix most problems. With TV's I have mainly been able to fix bad capacitor problems and other small issues I have never really tracked down a problem like this and don't know the names of the boards or which one is which. What board is the inverter board and where do I start? Do I need to check voltage? I know how to use a DMM just don't know where to start and what I should be checking. I am kind of learning more and more with each TV that I am asked to look at its kind of a hobby almost I like to be able to fix things instead of seeing them thrown out.
                • budwich
                  • Jul 2015
                  • 3097
                  no problem... the wording wasn't clear so rather than "fill in the words by guessing", it was better to "double check".
                  You should find the service manual somewhere (and for free)... especially for sony. I think most show that code as issues with the backlighting and since you never see it, I suspect that's where your problem lies. It could be a fuse (doubtful.... but maybe but usually that will mean there are issues further).
                  Of course, going thru the "tv repair reference library" thread on this forum is a good place to look ... ;-)
                    Training manual. AZ1K Chassis: DKL-**EX301/401400/400/501.
                    CTV-61 Training manual.
                    sony_ctv-61_AZ1K_chassis_training_manual.pdf
                    Page 19:
                    6X Blink - Backlight System Failure (46” Models)
                    The 46” models have both a 4X and 6X blink protection mode. The 4X blink will, in most cases, be caused by a defective lamp.
                    Because all the Backlight HV Inverter circuits are located on the GD2-Board, a 6X blink protection mode will be fixed, in most cases, by replacing the GD2-Board. If the GD2-Board does not repair the problem replace the A-Board. The BL-ON and Dimmer signals come from the microprocessor on the A-Board. A shorted or open BL-ON signal will cause this 3X condition. Also a shorted Dimmer will cause this 3X condition.
                    • dhoff024
                      • Mar 2013
                      • 96
                      Thanks for the help I will check the reference library and see what I find there. I am going to do some more research and see if I can find a service manual online. I will try to keep the thread as up to date as I can but I appreciate everyone's help so far this is the most difficult TV fix I have had so I will be pretty pumped up if I can get it fixed.
                      • tec3000
                        Sony LED 65X9005A shuts down after few seconds - looking for help
                        by tec3000
                        Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                        I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                        03-20-2024, 07:29 AM
                      • IamPritesh
                        Sony VJF152C11N DA0HKDMB6D0 shuts down in 1 min
                        by IamPritesh
                        So I have this Sony VJF152C11N ( Board Number : DA0HKDMB6D0 ) which came to me with no charging issue. The Charging IC was getting hot so replaced it.
                        ISL88732 replaced with ISL88731 and also the lower mosfet PQ59 ( NTTFS4C10NTAG ) with a similar N channel mosfet. Now the Charging is fine with 15.7 on BAT+ line but the new problem is that laptop boots till sony logo and then shuts down when battery is connected ( With or without AC adapter )
                        What could be causing this is a non compatible IC or FET or poor soldering or some kind of shorting?
                        07-31-2022, 05:23 AM
                      • Carlos#2003%
                        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                        by Carlos#2003%
                        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                        02-15-2024, 07:52 PM
                      • dkneyle
                        Sony KDL-46HX850 Can't upgrade/update firmware
                        by dkneyle
                        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                        09-25-2024, 10:44 PM
                        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-06-2024, 05:27 AM
