Lg 32LC46 Backlight cuts out after tv on for 3-4 sec
  • matyka
    • Jan 2015
    • 179
    • Uk
    Re: Lg 32LC46 Backlight cuts out after tv on for 3-4 sec
    Hi,resolder all the pins on all 8 transformers and the tv worked for about 30-40 min and now has the same fault.
    Dim Voltage =3.291v before and after backlight turns off
    BL-ON ??/I could not found .is BR1 the same ?
    BR1=2.070v
    How I block the protection OZ964GN ?
    • Maklaud
      • Sep 2015
      • 56
      • Russia
      http://english.electronica-pt.com/lcd-repair?p=OZ964
      • matyka
        • Jan 2015
        • 179
        • Uk
        I have a new inverter board and the tv is working now for the last 2 days.
        I measures all the 8 transf. on both boards and they are the same readings.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8352
          maybe one of those IC's are damaged that sit in front of each transformer.
          http://www.shopjimmy.com/cmo-27-d008...-inverter.htm#
            I wonder about the condition of those 4 filter caps on that inverter board.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              that too.
              • Maklaud
                • Sep 2015
                • 56
                • Russia
                #27
                I think some of the bad transformers. (I mean inside spark or closes).
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • DanPoka
                  by DanPoka
                  02-15-2025, 05:05 AM
                • Comp_Pro
                  No Backlight Macbook A1990 820-01041
                  by Comp_Pro
                  Hello all,
                  Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                  Tests performed:
                  There is no backlight even with a good screen.
                  Backlight IC is receiving the correct support voltages.
                  Fuse F8400 ok
                  Current sense resistor R8400 ok
                  Backlight IC is receiving 3.3V on enable pin.
                  Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                  Backlight IC receiving 5V from PP5V_G3S
                  Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                  I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                  05-06-2024, 10:23 PM
                • cheebster
                  iPad Pro 12.9 5th Gen Backlight Issue
                  by cheebster
                  Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                  Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                  Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                  The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                  Anyone...
                  05-20-2025, 09:17 AM
                • canadaboy25
                  LG Flatron 24EN33TA No Backlight When Cold
                  by canadaboy25
                  I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                  I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                  03-07-2023, 12:23 AM
