Inverter mod for Philips 47PFL7422 to disable dynamic backlight?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5095
    • New Zealand
    Re: Inverter mod for Philips 47PFL7422 to disable dynamic backlight?
    Originally posted by budm
    I believe if you disable on pin 11, the dimming function on the user menu backlights setup level will still work.
    That's the thing - the user menu brightness control doesn't adjust the backlights at all. It only seems to adjust the image gamma or some other property. The backlights stay at full brightness.
    -David VanHorn
      Brightness control is not the same as backlights level control.
      I just look up the user manual, there is no backlights level control for this model.
      There is the CONTRAST + which there is no explanation to what they are for.
      May be this is what it is for:
      https://cdn.badcaps-static.com/pdfs/...7e3a209c66.pdf
      Dynamic contrast enhancer
      You want the LCD flat display with the highest
      contrast and most vibrant images even at wide
      viewing angle. The Philips dynamic contrast
      enhancer uses video processing and unique
      dimming backlight technology.
      This delivers
      deep rich black levels with increased detail.
      The dimming backlight increases the contrast
      up to 5 times*
      , and at the same time improves
      the viewing angle. It gives a bright, lifelike
      picture with high contrast and vibrant colors,
      (* factor between 2 and 5, scr.
      So you are correct that if you want to be able to adjust the backlights level then I would use DC DIMMING control but then the user has to be able to set it some how since it is not adjustable in the user menu.
      • eccerr0r
        inverter H tree driver imbalance in an AC inverter
        by eccerr0r
        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
        11-16-2025, 12:34 PM
      • brotank
        Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
        by brotank
        I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
        can someone disable onboard ram from my dumped bios, please 🙏
        I tried the other bios on this forum with disabled onboard ram, but no success
        my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
        after that I officially give up 😂
        thanks for awesome jobs 😊...
        03-16-2025, 12:51 PM
      • x_orange90_x
        by x_orange90_x
        01-29-2025, 09:24 PM
      • alro7779
        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
        by alro7779
        Hello, guys!
        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
        09-14-2025, 12:25 AM
      • G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
        by G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
        It does power up when pressing the power button.
        I already try the power button while plugin the plug with no result.
        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
        Could this be an PSU or eMMC issue ?
        07-19-2025, 03:43 AM
