Inverter mod for Philips 47PFL7422 to disable dynamic backlight?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5035
    • New Zealand
    Re: Inverter mod for Philips 47PFL7422 to disable dynamic backlight?
    Originally posted by budm
    I believe if you disable on pin 11, the dimming function on the user menu backlights setup level will still work.
    That's the thing - the user menu brightness control doesn't adjust the backlights at all. It only seems to adjust the image gamma or some other property. The backlights stay at full brightness.
    -David VanHorn
      Brightness control is not the same as backlights level control.
      I just look up the user manual, there is no backlights level control for this model.
      There is the CONTRAST + which there is no explanation to what they are for.
      May be this is what it is for:
      https://cdn.badcaps-static.com/pdfs/...7e3a209c66.pdf
      Dynamic contrast enhancer
      You want the LCD flat display with the highest
      contrast and most vibrant images even at wide
      viewing angle. The Philips dynamic contrast
      enhancer uses video processing and unique
      dimming backlight technology.
      This delivers
      deep rich black levels with increased detail.
      The dimming backlight increases the contrast
      up to 5 times*
      , and at the same time improves
      the viewing angle. It gives a bright, lifelike
      picture with high contrast and vibrant colors,
      (* factor between 2 and 5, scr.
      So you are correct that if you want to be able to adjust the backlights level then I would use DC DIMMING control but then the user has to be able to set it some how since it is not adjustable in the user menu.
      • brotank
        Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
        by brotank
        I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
        can someone disable onboard ram from my dumped bios, please 🙏
        I tried the other bios on this forum with disabled onboard ram, but no success
        my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
        after that I officially give up 😂
        thanks for awesome jobs 😊...
        03-16-2025, 12:51 PM
      • x_orange90_x
        Vizio E55-E1 bad backlights or bad inverter?
        by x_orange90_x
        I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
        I don't know how exactly to test the inverter itself. Is it...
        01-29-2025, 09:24 PM
      • alro7779
        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
        by alro7779
        Hello, guys!
        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
        09-14-2025, 12:25 AM
      • G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
        by G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
        It does power up when pressing the power button.
        I already try the power button while plugin the plug with no result.
        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
        Could this be an PSU or eMMC issue ?
        07-19-2025, 03:43 AM
      • Gentian
        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
        by Gentian
        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
        03-06-2023, 07:07 AM
