Inverter mod for Philips 47PFL7422 to disable dynamic backlight?
    replied
    Re: Inverter mod for Philips 47PFL7422 to disable dynamic backlight?
    It is one of those Dynamic Contrast so they can claim that the TV has contrast ratio of 100K: 1 or more which is a phony number.
    There should be a small cables from the T-COn that has control output signal to tell the backlights circuit to dim down the backlights in certain scene of the image such as when you watch space movie so the dark will be really dark.
    You can see that white flat ribbon cable between the T-CON and the inverter board. You can look up the LCD panel so you can get the pinout of the inverter board. You shoulld be able to disable the function in the user manual, or may be not in certain TV.
    A lot of people complain about this function.
    http://www.cnet.com/news/just-whats-...-ratio-anyway/
    http://lcdtvbuyingguide.com/hdtv/dynamic-contrast.html
  • Inverter mod for Philips 47PFL7422 to disable dynamic backlight?
    A friend of mine has a Philips 47PFL7422 LCD TV and it includes some kind of dynamic backlight feature which automatically dims the backlight when the image onscreen is dark, probably to save power.
    Unfortunately, it seems too aggressive and can do it during dark scenes in films which creates a horribly jarring effect when the backlight level changes suddenly.The problem is also described here: http://www.geekzone.co.nz/forums.asp?topicid=22737
    In any case, for this model there is no service menu adjustment to turn the feature off, nor were Philips ever forthcoming with a firmware update, apparently. Which is stupid, since the brightness control in the main user menu doesn't do a thing to adjust the backlights either - it simply adjusts what seems to be the picture gamma. That's two things they should have fixed. Anyway....
    The TV has two inverter boards, a CMO I420H1-20B-MASTER and a CMO I420H1-20B-SLAVE. Since these aren't made by Philips, they don't appear in the schematic, of course. They're based on the OZ9928SN.
    From what I measured, however, the Master inverter board receives at its "E-PWM" pin, a PWM signal from the mainboard which is about 3.3v p-p and has a duty cycle of I guess about 99% (see first scope shot, DSC02108.JPG). The duty cycle of this signal does NOT change when lowering the "Brightness" control in the main menu, although you can see the image get duller as it appears the gamma or such is changed.
    At ~3 divs and 0.5ms per div, this seems to be about 666Hz.
    The inverter also receives 3.3v from the T-CON board, to a pin labelled "DIM-IN", and this appears on the pin "DIM-OUT" as well, which seems to go back to the T-CON board. This signal does not appear to be a PWM signal - if it is, it's at 100% duty cycle or so close to it that I cannot see where it goes to 0v at any point. This signal also does not change when the brightness value in the menu is changed.
    When the backlight dimming feature kicks in, both the "E-PWM" and "DIM-IN" lines change to a square wave with much lower duty cycle, around 30%, and the frequency seems to drop to 166Hz (3 divs at 2ms per div). The "DIM-OUT" line also changes, with a slower falling edge.
    See:
    DSC02108 for E-PWM normal brightness
    DSC02110 E-PWM dimmed
    DSC02111 DIM-IN dimmed
    DSC02112 DIM-OUT dimmed
    My original idea was to disconnect the "E-PWM" line from the mainboard and attach my own PWM generator using a microcontroller to give a constant PWM signal that would not be affected by the TV software. However, this was before I found that the T-CON is also involved. Now I am not so sure what to do.
    I could of course disconnect both E-PWM and DIM-IN, and feed them the same signal (probably from separate pins on the microcontroller or using an optoisolator so they are not tied together directly), but I wonder if the T-CON would not be impressed that the DIM-OUT signal would no longer match up with what DIM-IN was.
    It doesn't help that there seem to be no good datasheets for the OZ9928, and the inverter schematic seems nonexistent (as usual). I did find http://wenku.baidu.com/view/d58277c4...6bcebbc4c.html and a few similar websites which claim to have the schematic but you have to pay to download it and I don't speak Chinese!
    Does anyone have any ideas or experience with this kind of thing?
  • brotank
    Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
    by brotank
    I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
    can someone disable onboard ram from my dumped bios, please 🙏
    I tried the other bios on this forum with disabled onboard ram, but no success
    my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
    after that I officially give up 😂
    thanks for awesome jobs 😊...
    03-16-2025, 12:51 PM
  • x_orange90_x
    by x_orange90_x
    01-29-2025, 09:24 PM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • Gentian
    APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
    by Gentian
    I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
    It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
    03-06-2023, 07:07 AM
  • valvashon
    Insignia NS-LCD19-09 (PS OK, Inverter problem?)
    by valvashon
    For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
    History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
    01-04-2024, 01:44 PM
