Lg 50PA650t. No picture.
  • Ice203
    • May 2015
    • 99
    • Uk
    Hi. Just been give the above TV. Has sound but no picture.
    Tried the flash light test and can't c any image.
    So no wondering what I need to test next.
    Thxs
  • CapLeaker
    Leaking Member
    • 8325
    Re: Lg 50PA650t. No picture.
    https://www.badcaps.net/forum/showthread.php?t=39740
    • Hamie
      • Apr 2014
      • 1383
      Is this not a plasma??
      Why would you do a flashlight test on a plasma?
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
      • chth96
        How Can I test PWM DM0365R?
        by chth96
        Hello
        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
        06-18-2025, 04:14 PM
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • khelane
        test active pfc power with lamp test
        by khelane
        Hello
        I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
        Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
        Is there a way...
        06-03-2025, 01:00 AM
      • chronic519
        Mats / mods: detected and repaired GPU fault. Cant seem to test after!
        by chronic519
        Hello.
        GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
        Found issue with a RAM block
        Replaced, green lines gone.
        Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
        Used a good card to test and same results low errors 32+.
        I am just search for some form of command to do a full test on the GPU.
        I just ran the mats command with my good GPU and passed after roughly 40 min.
        The repaired one, ran...
        05-20-2025, 07:56 PM
