Samsung UN32F6300AFXZA black screen red flashing lights
  • Davegerg
    • Aug 2012
    • 62
    Re: Samsung UN32F6300AFXZA black screen red flashing lights
    At least you didn't say: https://www.badcaps.net/forum/images...es/lolsign.gif That's OK, I deserve it.
    I tested the other four strips with the same PS - but only for about 1-2 seconds. Do you think I caused much/any permanent damage to them? I'd like to know before investing any money in buying a new strip.
      I could not tell you for sure if they are damaged or life is shortened or not.
      • Davegerg
        • Aug 2012
        • 62
        Hey, the TV actually works! For how long, who knows? I replaced the blown LED with one from a broken computer monitor. Works fine, but it's a little brighter and there's a small 'ghost' on the screen. If it plays for a week or so, I will try to find the correct LED. Thanks for all the help.
        • CapLeaker
          Leaking Member
          • 8326
          well... there is another trick. replace the bad led with a zener diode.
          • Davegerg
            • Aug 2012
            • 62
            Wouldn't that leave a dark spot in the grid? Each strip has 9 LEDs and there are 5 strips.
              If you have all white screen then you may notice it, but when you watch moving images you may not notice at all unless some one point out the location of the bypassed LED.
              BTW, you should turn down the backlights level so the LEDs will run cooler.
              The typical current for LED in TV is in 100's mA range so what ever you put in must be able to handle that much current.
              • Davegerg
                • Aug 2012
                • 62
                Thanks for the tips. I've had it on about 4 different times for an hour with no issues. The 'ghost' only appears when the background is white. You hardly notice it with darker colors. I turned down the bl level from 20 (max) to 7. Didn't help with the 'ghost' and the picture still looks good. I may experiment by adding a small shade right above the LED. My goal is not spend any more than the cost of the TV - $5 at a garage sale. Now, if I counted my time, that would be another matter.
                  "Now, if I counted my time, that would be another matter." but if you think of how much you learn from the times spent on this project, the knowledge you gain from this is worth way a lot more.
                  I learn lots of new knowledge from this site everyday.
                  • CapLeaker
                    Leaking Member
                    • 8326
                    x2 budm
                    • HTR-Informatique
                      by HTR-Informatique
                      02-09-2025, 06:51 AM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • Chrissygizmo
                      samsung galaxy ao2s very temperamental after screen replaced
                      by Chrissygizmo
                      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                      Ive eventually managed to get it on and working but it's very temperamental...
                      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                      05-26-2024, 12:05 AM
                    • JunkmanJimbo
                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                      by JunkmanJimbo
                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                      Please help. Thanks in advance!
                      08-12-2025, 11:45 AM
                    • Kiberge
                      Samsung LH82QENELGC/EN Help needed - Static line on screen
                      by Kiberge
                      HI guys!
                      I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                      I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                      the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                      This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                      04-22-2024, 11:28 AM
