Polaroid 3211-tlxb
  • junktv
    • Nov 2010
    • 3065
    Polaroid 3211-tlxb
    So this 3211-tlxb has a worsening problem. I'll turn it on and after it comes on it makes a pop sound in the speakers and turns back off. The red stand by light is on and turns to blue when it powers up but back to red when it shuts down.
    I was hoping it had the same board as my Element 3211b since I had the two caps but it doesn't. All the caps look fine to me.
    The place I circled had 2 HEC ZD 1000uf 10v caps. Any ideas?
  • junktv
    • Nov 2010
    • 3065
    Re: Polaroid 3211-tlxb
    Going to buy a new tv anyway but would like to get this one going. Does this even seem like a problem that would be in the power supply or something in the main board?
    Tv off is
    5v is 5.12v
    12v is 0v
    24 is 0v
    Tv on is
    5v is 5v
    12v is 11.7v
    24vis 23.8v
    • CapLeaker
      Leaking Member
      • 8177
      easy. You are getting correct voltages from the PSU. To figure out what happens (I say it is the main board's fault), turn the TV on and let it run until it shuts down. I bet that the PSon voltage from the main board to the PSU is gone, and thus the PSU turns effectively the TV off.
      • junktv
        • Nov 2010
        • 3065
        I guess PSon is "power supply on"? Would that be a 5v to the main board? I guess it should drop before it shuts off?
        It's actually staying on now so I'm leaving it on for the peace and quiet. I did notice slight fluctuation in the 12v last time I powered it up. It dropped to 11.5v then back up to 11.7.
        • CapLeaker
          Leaking Member
          • 8177
          Take a measure of PSon when the TV is working correctly and take another measure when the TV turns off and compare. When the TV turns off, PSon voltage drops either too low for the PSU to stay on or zero.
          • junktv
            • Nov 2010
            • 3065
            Ok none are labeled PSon but I tested the 5vsb and when it turns off it drops down to 1.4v for a second or 2 then comes back to 5+v. When it drops it is a split second after the backlight goes out.
              Stb = ps-on
              <1VDC = OFF, >2VDC = ON
              • CapLeaker
                Leaking Member
                • 8177
                5vsb is your STBY voltage, that should be always there and it shouldn't drop to 1.4V either. So, I think you should force the PSU and the backlight on and disconnect the main board. Take two 1k ohm resistors and jump 5vsb to PSON and from 5vsb to BLon (backlight). All power rails should be up and the backlight on.
                • junktv
                  • Nov 2010
                  • 3065
                  Thanks I had no clue where PSon is. When testing the stb it drops from 4.8v when on down to .06 but only drops a split second after the speaker pop and back light goes out.
                  As far as jumping I dont have any resistors unless i can dig one out of something else that had died or been scrapped.
                  • CapLeaker
                    Leaking Member
                    • 8177
                    How long does it take to get the speaker pop? Feel around on the main board, maybe something gets hot?
                    I am pretty sure the problem is on your main board. Just would be nice to really make sure and see if the PSU works correctly without having a hiccup.
                    • junktv
                      • Nov 2010
                      • 3065
                      Kinda depends. some times it will stay on other a couple seconds or minutes. Not feeling anything warm or hot. Any other way to check?
                      • junktv
                        • Nov 2010
                        • 3065
                        Would these work? http://www.radioshack.com/1k-ohm-1-4...k/2711321.html
                        • CapLeaker
                          Leaking Member
                          • 8177
                          that would be fine
                          • junktv
                            • Nov 2010
                            • 3065
                            Ok they didn't have the ones I linked so got these. http://www.radioshack.com/1k-ohm-1-2...5/2711118.html
                            So you want me to unplug the main board then jump from 5vsb to stb on the power supply and also 5vsb to BLon which is what pin?
                            Am I just seeing if it kicks off this way or should I be measuring?
                              The BL-ON (invr-on) signal is NOT routed through the power supply board connector in this TV, the BL-ON (INVR-ON) pin will be right at the Inverter board connector.
                              That is why we always ask for the pictures of the whole backside of the T so we can see how all the boards are connected together. Polaroid is one of those bad design and hard to get to some of the boards.
                              • junktv
                                • Nov 2010
                                • 3065
                                This shares the same body as my element and yes it is a pain to get to the back light boards. Sounds like that will be needed. Here is what is easy to get to.
                                  Yep, I hate their design, there is big connector on the main board (bottom left of the board, 50 pin connector) that goes to the inverter board.
                                  • junktv
                                    • Nov 2010
                                    • 3065
                                    I don't actually see a connector on the bottom of the main other than for inputs. I guess I'll yank it apart and update.
                                      When you pull that whole assembly out, you will see the connector underneath.
                                      • junktv
                                        • Nov 2010
                                        • 3065
                                        OK got it apart.
                                        • Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                          by Stephen
                                          MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                          03-15-2024, 09:37 AM
                                        • mnciks11
                                          Lenovo G50-80 turns on and quickly shuts down
                                          by mnciks11
                                          Hello guys, i need your help fellow brothers
                                          Im diagnosing a Lenovo G80-50 laptop
                                          ACLU3/ACLU4
                                          Rev : 1.0
                                          when you press the power button, the LED power light turns On and quickly shuts down, no display, fan spins a sec and stop. I haven’t seen any short so far.
                                          PU908 (CPU POWER CORE CHIP) is getting hot the moment you press the power button, the laptop turns off very fast, i changed PU908, still im getting same problem, on output side of the 2 cpu power supply coil i get 1.6v and then goes away as soon as the laptop turns off, still the...
                                          05-12-2020, 12:38 PM
                                        • ZixuTech
                                          Turns on and shuts off NUC8I7HNK4 needed a BIOS
                                          by ZixuTech
                                          Seems like we are dealing with a case of a corrupted BIOS after Intel Driver software attempted to flash the bios (haven't seen that before). The customer reported seeing a BIOS message while the screen was flickering during the Intel Display Driver installation. This was while the BIOS WRITE lock jumper was in place. Resulting in Loop restarting.
                                          Afterwards, the customer attempted flashing BIOS via USB stick, resulting now in turning and immediately shutting down unit NUC8I7HNK4.
                                          Under the thermal cam, I can see that the CPU is initiating a heat signature for a second...
                                          08-13-2023, 08:55 PM
                                        • www
                                          LG L192WS-BN backlight turns off after 1 second
                                          by www
                                          I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                          I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                          03-24-2024, 05:26 PM
                                        • mferna14
                                          Hp 15-ca2003ca DAG7BDMB8F0 turns on & shuts off
                                          by mferna14
                                          Hi all, I am working on Hp 15-ca2003ca (MB DAG7BDMB8F0 REV:F). The problem was totally dead. Upon diagnostics, there was a burnt SY8286BRAC. I replaced it with another one. Now the WHITE LED on the DC-in jack glows & when the main battery is installed, the status of the LED changes to Orange. But when I press ON/OFF button, I see the power LED glows for a sec & then shuts off. Same happens when I press the ON/OFF button over again. I just put the Meter leads on the 3.3/5V coils & the meter shows that these both volts are generated & then in a sec. goes away. I re-programmed the...
                                          07-11-2022, 02:29 PM
