Philips 46pfl5505d/f7
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Philips 46pfl5505d/f7
    Well... after going cross eyed on the board tracing from the pictures, I did find a SM for the PL10.7 chassis. So that BLon signal comes from IC3101. So I Guess you are SOL. You can still verify voltage and do the heating and cooling thing there, bake the main board a bit etc.
    • krygods
      • Dec 2014
      • 257
      Well that was fun, and we narrowed down the issue. I'll put this one in the closet and keep an eye out for another identical set with bad or cracked panel or a main board on ebay if one ever shows up.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5096
        • New Zealand
        #83
        Did you check on mainboard that C3067 is not shorted and R3022 or R3323 is not open?
        If those parts are bad they could affect the signal coming from IC3101
        -David VanHorn
        • krygods
          • Dec 2014
          • 257
          I'll pull the TV back out of the closet and check on those thanks for the advice.
          • krygods
            • Dec 2014
            • 257
            I found this main board on ebay. Wondering if this will work for the 46pfl5505d/f7??
            http://www.ebay.com/itm/121760817526...%3AMEBIDX%3AIT
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8352
              It may work o.k. Yours and that main board on e-bay use the same t-con board. However that one on eBay has more things. Notice the network jack? So you may have to make some holes on the back cover.
              • krygods
                • Dec 2014
                • 257
                Cool, I'll go ahead and get that as soon as I can. Making holes in the plastic isn't a problem.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8352
                  Check both of them out on shop jimmy.
                  • krygods
                    • Dec 2014
                    • 257
                    Looks like it should work, the both show the same panel number.
                    • krygods
                      • Dec 2014
                      • 257
                      Well the 46pfl5505d/f7 lives again!
                      I ordered the main board I mentioned in post #85 TV is running once again.
                      Also since this main board was from a 46PFL5705D/F7 the TV now has Netfilx capability!
                      Thanks everyone who helped out in troubleshooting this TV, it was a good long learning experience!
                      Another TV can now find a new home rather than the dump.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8352
                        Nice upgrade! Another TV saved from the landfill.
                        • ziddey
                          • Sep 2015
                          • 35
                          • usa
                          #92
                          Just chiming in to say it looks like D951 is a common point of failure for these TVs. Another one saved thanks to you guys and this thread.
                          • What?
                            • Aug 2010
                            • 82
                            I know this post is old but, I had the same problem with my Philips 46PFL5505D/F7 and this post helped me solve the problem. Another D951 failed, I replaced D950 and D951 with a TO-220 10amp 80v diode with a heat sink. Since there is no place to mount the heat sink (and it is too tall) I laid it on it's side and glued it to the board.
                            I just wanted to say THANK YOU for your help, BadCaps is awesome!!
                            • Sharpa
                              Repair attempt Philips 55OLED804/12
                              by Sharpa
                              I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                              The symptoms when bought: Philips logo appears then tv turns off
                              Things tried so far:
                              1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                              2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                              11-22-2025, 08:30 AM
                            • alro7779
                              Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                              by alro7779
                              Hello, guys!
                              The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                              09-14-2025, 12:25 AM
                            • G33RT
                              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                              by G33RT
                              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                              It does power up when pressing the power button.
                              I already try the power button while plugin the plug with no result.
                              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                              Could this be an PSU or eMMC issue ?
                              07-19-2025, 03:43 AM
                            • ivtec
                              Philips 46PFL5505D/F7 thin green line?
                              by ivtec
                              Hi guys i have this Philips 46PFL5505D/F7 that has a thin green line in the corner almost unnoticeable ,this probably has been here for a long time,and it more noticeable when watching regular tv entertainment,since i mostly watch soccer on this tv because of the green field ,it's probably i never noticed it ,do you guys think this might be the ribon cables , tcon board or main board ?...
                              12-24-2020, 12:57 PM
                            • double_DD
                              Philips curling iron - is this a common AC cable?
                              by double_DD
                              Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                              As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                              Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                              08-18-2025, 10:04 AM
