Philips 46pfl5505d/f7
  • Agent24
    I see dead caps
    • Oct 2007
    • 5036
    • New Zealand
    Re: Philips 46pfl5505d/f7
    Looks like D951 is the one that's shorted. See how the meter shows a very low reading in both directions?
    What you are looking for is the forward voltage drop (average is 0.6v or 600mV) in forward bias (that is, the positive lead connected to anode and negative to cathode) and in reverse bias you should have no voltage drop at all, or rather, an open circuit (your particular meter shows this, or other out-of-range condition as a "1" on the far left of the display).
    What your diode shows is 2mV voltage drop both directions which means the diode is now acting much the same as a piece of wire.
    -David VanHorn
      Originally posted by krygods
      This is D951
      Bad. You should put in new battery for you meter.
      • krygods
        • Dec 2014
        • 257
        Diode says SB260 on it.
          Schematic shows as SB260.
          https://cdn.badcaps-static.com/pdfs/...778b06be8a.pdf
          • krygods
            • Dec 2014
            • 257
            Anything I can find one of these in or is it easier to just order one and wait for it to arrive?
            • Agent24
              I see dead caps
              • Oct 2007
              • 5036
              • New Zealand
              #26
              For reliability it might make more sense to upgrade to a single, higher current diode and install that in the unused D952 space. (If one suitable exists)
              -David VanHorn
                The spec recommends 0.375" lead length on each side for it to handle If rating based on Ta of 25C.
                It looks like the leads are cut too short, I would replace both of them and keep the lead length as long as possible. The bad thing about using two diodes in parallel is that the Vf should be matched otherwise one will conduct more current than the other.
                • krygods
                  • Dec 2014
                  • 257
                  So it makes sense to buy a good quantity of them and find two that are closely matched?
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8326
                    I don't really like installing 2 diodes in parallel, I rather like to upgrade the single diode with something bigger and heavier... I't doesn't have to be a SB260, as long the replacement has at least the same voltage and current capabilities, is a fast switching schottky diode.
                      I myself would use TO-220 case type DIODE mounted on a heatsink.
                      • krygods
                        • Dec 2014
                        • 257
                        I like the idea of upgrading to prevent future failure. What is required to upgrade to a single diode? what diodes are removed, where does the single one go? Do I have to jump any traces due to the missing diodes?
                        • CapLeaker
                          Leaking Member
                          • Dec 2014
                          • 8326
                          you have to keep ZD951, that is your overvoltage protection. But D950 and D951 you can take out and put a single heavy diode in its place. Depending on the casing style diode (lets say TO-220) you have to add a heat sink.
                          The SB260's are 2 amps, 60V each. So whatever diode you chose has to be at least 4 amps, 60V, since they were two in parallel. So you don't want that to happen again, put an 5 or 8 or 10 amp, 80 to 100V schottky into it. Where does it go? D950 and D951 have to be removed and you could use either D950, D951 or D952 to put the new large single diode in.
                          So a SB5100 (5A/100V), a SB580 (5A/80V) axial or a 8TQ100 (8A/100V) TO-220 with heat sink etc. I am sure you get the idea now.
                          No, you don't put any jumpers.
                          • krygods
                            • Dec 2014
                            • 257
                            • krygods
                              • Dec 2014
                              • 257
                              I have an NTE573 60V 5A, is this suitable for as a single diode or does the voltage need to be higher?
                                That should be OK, but you must keep the legs length as long as possible ans noted in NOTES 1 of the spec sheet (but it is not likely that the ambient will be at 25c). You can use it and see how hot it gets.
                                • krygods
                                  • Dec 2014
                                  • 257
                                  Okay so I installed the diode. TV turned on and functioned properly. I turned the TV off and now when I try to power it on the White LED blinks 21 times pauses for a second and continues to blink 21 times over and over until the power is unplugged.
                                  • CapLeaker
                                    Leaking Member
                                    • Dec 2014
                                    • 8326
                                    Start a new diagnosis. Check all voltages, force on the PSU without the main board etc.
                                    • krygods
                                      • Dec 2014
                                      • 257
                                      So I re-checked all the diodes, all test good. I checked for voltage at CN2 here is what I've found. No voltage at Pin 9 or any other Pin at CN2, except Pin 11 at CN2 shows -6VDC.
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8326
                                        This doesn't make sense. Pin 9 is your 5.3 STBY and pin 11 is GND. So if pin 9 is zero Volts, nothing would work at all... no blinking led, nuttn.
                                          Must be measurement error.
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • ivtec
                                            Philips 46PFL5505D/F7 thin green line?
                                            by ivtec
                                            Hi guys i have this Philips 46PFL5505D/F7 that has a thin green line in the corner almost unnoticeable ,this probably has been here for a long time,and it more noticeable when watching regular tv entertainment,since i mostly watch soccer on this tv because of the green field ,it's probably i never noticed it ,do you guys think this might be the ribon cables , tcon board or main board ?...
                                            12-24-2020, 12:57 PM
                                          • double_DD
                                            Philips curling iron - is this a common AC cable?
                                            by double_DD
                                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                            08-18-2025, 10:04 AM
                                          • janos6662000
                                            Philips 47PFS7509/12 LCD TV problem
                                            by janos6662000
                                            Hi
                                            I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                            When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                            I downloaded original firmware and applied the update, but the problem remained.
                                            From a colleague i received a "factory package software" which is a lot bigger.
                                            I made another firmware update, but still did not solve the problem.
                                            Somewhere on the way the error got worse, because at the moment the...
                                            08-12-2025, 12:54 PM
