Need help with power supply on 55" TV
  • Matt8110
    • Sep 2015
    • 12
    So, yesterday I got a free 55" Vizio TV. The model number is VF550M. The guy I got it from said it just stopped working a couple days ago. I tried it and I was able to turn it on but there was no picture or sound. So, I took it apart and did some diagnosing and realized I was getting 5v standby power but only 0.6-0.8 volts on the 12 and 24 volt output! That immediately told me it was the power supply. I know a bit about electronics, but I'm not too experienced with power supplies. So I tried looking up basic things that could be wrong and found I either couldn't understand what they were talking about or that wasn't the issue. I was hoping someone on here might be able to help me diagnose and fix this board. I have 2 other power supplies for parts from other TVs with destroyed screens. Besides that the only tools I have are screw drivers, a soldering iron, and a multi-meter. I don't really have money right now to buy a new board so I was hoping I could fix this one. There aren't any noticeably blown capacitors and anything else for that matter. The board looks fine and smells fine. Thank you
  • Emu9x
    • Sep 2015
    • 12
    Re: Need help with power supply on 55" TV
    I'd be looking at the transistors, there are usually the problem with psu boards not getting enough power! in my experience if the 3.3v, 5v, 12v and 24v are missing then the transistor if the first thing i check!
    • Matt8110
      • Sep 2015
      • 12
      Thank you, how would I go about testing the transistors?
      EDIT:
      Also, would I be getting some voltage if a transistor was bad?
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        Standby voltage are created in a separate circuit from the 12 and 24v
        found a repair kit for this power supply, looks like it has a common mode of failure and a bunch of parts that go.
        Test out these parts on your board
        IC601, 651, 800, 801, 901
        D806, ZD902
        R667, 841, 847, 917
        Q601, 602, 651, 652, 808, 809
        F1
        Liberating magic smoke one part at a time
        • Matt8110
          • Sep 2015
          • 12
          Will do. I can test Diodes, Resistors, and Fuses. But I'm still unsure how to test transistors. I've looked online and can't seem to find a straight answer.
          • johnboy1313
            • Nov 2012
            • 1959
            Are you sure it's the power supply? The signal to turn the PSU on comes from the mainboard.
            • Matt8110
              • Sep 2015
              • 12
              Yes, I am sure. The power supply turns on just fine. I have even tried it with nothing plugged into it with a jumper wire from 5v to PSON and I still get less than a volt from the 12 and 24v pins.
              • Matt8110
                • Sep 2015
                • 12
                I'm reading 0 ohms accross resistor 667....Is that even possible?!
                • CapLeaker
                  Leaking Member
                  • 8214
                  Anything that raises your eyebrows and you test it in circuit, always test it out of circuit again. There may be something in parallel in circuit that is shorted, like a diode or transistor.
                  • Matt8110
                    • Sep 2015
                    • 12
                    Thank you, I took that one out of circuit and it tested fine. All the others tested fine as well and so did the diodes. I'm not entirely sure how to test the ICs or Transistors at this point, but at this point I'm guessing it's probably a transistor....
                      Is this your power supply board?
                      http://www.shopjimmy.com/vizio-0500-...upply-unit.htm
                      You need to find out first if you do have PFC Boosted Voltage of >360VDC measured between the two legs of the main filter cap when PS-ON is applied, no boosted Voltage = no 12V/24v.
                      • Matt8110
                        • Sep 2015
                        • 12
                        I just tested it. I'm getting a steady 351 volts DC.
                        • CapLeaker
                          Leaking Member
                          • 8214
                          It's a bit low, but we have seen that before, good news is that the PFC is working!
                          I don't have a schematic in front of me to see that circuit
                          • Matt8110
                            • Sep 2015
                            • 12
                            I could post some pictures if that'd help.
                              351VDC is on the low side enough for the 12V/24V SMPS IC protection circuit to lock down the circuit since at lower Voltage it will require more current to maintain the power out of the power supply.
                              We will need the P/N of the 12V/24V SMPS IC to look up the spec sheet to see how it operates.
                              • Matt8110
                                • Sep 2015
                                • 12
                                Would that be on the hot or the cold side?
                                EDIT: Regardless here is a list of all the ICs I can find on the board.
                                Top of the board:
                                -LM293N
                                -Either 60915LP or G0915LP...
                                -ice382065p
                                Bottom of the board:
                                2 -DLA001D
                                But as I said, I am getting something out of the 12 and 24 volt outputs....Around 0.8 volts on the 24 and 0.6 on the 12....
                                  Disconnect the cable to the invereter board to see what will have happen.
                                  0.8V, 0.6V are just stray Voltage readings.
                                    DLA001D is supposed to be the same as L6599 by ST Micro but I am not 100% sure.
                                    See exaple circuit so you can at least test the VCC pin.
                                    http://www.st.com/web/catalog/sense_...SC354/PF129679
                                    • CapLeaker
                                      Leaking Member
                                      • 8214
                                      Hi res pictures can say more than words. So yes... it does help.
                                      • Matt8110
                                        • Sep 2015
                                        • 12
                                        I figured they were stray voltages. I tried it with nothing but the main board plugged in and without it being in the TV at all. And I will test the VCC on that chip when I get the chance, thank you.
                                        EDIT: My phone can only take 5MP pictures, so I'll have to see if I can find one of my cameras, I think one is 10MP or so.
