Sharp lc-70c6500u
  • dam2729
    • Aug 2015
    • 8
    • us
    Sharp lc-70c6500u
    I have 2 Sharp lc-70c6500u and both are bad i trying to figure out if they are fixable .one tv has green lines and the second tv has a dim picture and it is flickering.
  • dam2729
    • Aug 2015
    • 8
    • us
    Re: Sharp lc-70c6500u
    How do u tell if it is a bad board?
    • johnboy1313
      • Nov 2012
      • 1959
      the one with green lines is almost certainly a bad panel. The other one could be a bad LED, but I would think it would throw a 1-1 code if that were the case. I'm leaning toward bad panel on that one as well.
      • jetadm123
        • 2169
        Agree with johnboy that the panel on the first one is probably bad, which hopefully means the boards are still good. That being the case, try swapping the boards, one at a time, over to the dim screen to see if it solves the problem.
        • dam2729
          • Aug 2015
          • 8
          • us
          can u fix a bad panel ? is it just the tabs coming loose? I had a sony that i put little pieces of rubber between the frame and plastic and it fixed it.
          • jetadm123
            • 2169
            You can try pressing on the tab bonds to see if that changes anything. If not, then it's the panel itself and there's no repairing that.
            • dam2729
              • Aug 2015
              • 8
              • us
              thanks im going to try switching the boards
              • nwcs
                • Dec 2015
                • 311
                • usa
                I hate to drag this one up again but before I bother trying to do the tab bonds I would like some input. I have lines in this tv but no mater which side of the tab's I remove the lines do not go away. When I remove the left side from the tcon I still get lines on opposite side and there are what looks like defects in the panel bottom lower left side. If I remove the right side from the tcon I get lines through both sides of the picture. I am guessing this is a bad panel and just wanted input before I start the surgery.
                • geeforce
                  • Oct 2017
                  • 87
                  Is pic 4 supposed to be black? Leaving towards left side failure and tab removal... I'm a newbie to this though.
                  • nwcs
                    • Dec 2015
                    • 311
                    • usa
                    No it should not. It gets darker the longer the TV is on.
                    • budwich
                      • Jul 2015
                      • 3097
                      does the set have edge boards running up and down the side?
                      The dark side (right) is caused by that side NOT get proper powering to the tabs on that side. I wouldn't do anything quite yet until you do more looking around.
                      • nwcs
                        • Dec 2015
                        • 311
                        • usa
                        Yes it does. I have not had good luck repairing bad tab's so if I do this I will have to get the customer to understand that it may not repair the problem. I have not removed the panel braces yet. I did look around and do not see anything that would alert me to other issues.
                        • budwich
                          • Jul 2015
                          • 3097
                          OK... so the "real test" for this type of set is to disconnect the small corner cable at the bottom of the panel that interconnects the bottom edge board to the side edge board. This allow you to potentially see the WHOLE display / picture... then look at the result. Do this test on both sides to check the result.
                          My guess based on your pictures, is the panel has TWO problem... one related to the right side (maybe the corner cable is not actually seated properly... or maybe the bottom edge board has a blown smd component on it that feeds that side) and then left side has a tab issue somewhere related to the horizontal lines. :-( Two "fails" are tough to overcome... BUT if indeed the bottom edge board has an SMD problem... you might be able to address this and then deal with the left. Go slow.
                          • nwcs
                            • Dec 2015
                            • 311
                            • usa
                            I will put the tv back up and try that.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4536
                              • Italy - Milan
                              Is it a Sharp panel? What i suggest is not much scientific but it's almost the thing i have done on an another Sharp panel tv, save the content of the tcon's eeproms, cut the vcc on the panel's pcb's where it goes on the last tab's last traces, the ones that runs through them without entering the COF (chip) and that feeds power to the side tabs, then switch tv on, now re join the cut traces, re-power tv and see if it works, if you don't have more an image rewrite the eeproms with the saved bin and retry the tv. Theese are desperate solutions because as Budwich says it's almost clear you have a problem on both sides tabs.. and a tabs removal can't save the screen.
                              • nwcs
                                • Dec 2015
                                • 311
                                • usa
                                Yes it is a sharp panel and before I do any surgery I have to talk to the customer but if they approve it then I will try what you suggest.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4536
                                  • Italy - Milan
                                  For instance in SHarp panels VCC i think it's a 3,3v.
                                  • nwcs
                                    • Dec 2015
                                    • 311
                                    • usa
                                    So, when I unplug the corner cable on one side then the other The side I unplug is dark and the other side is light. With booth sides hooked up now the bottom of the picture is not working. Now if I tap the tab bonds one a a time on the left side 2nd one up the bottom half of the picture shows up and if I go up two more and tap it, it is very hot to the touch. There is no change if I do this to the right side. Also now when I plug in the middle left tab connector the sharp logo shifts so that the left half is on the bottom and right half is correct and in the center or sometimes I get no picture with it connected. I did find some corrosion on the first of second tab board on the left hand side in one of the connectors. I cleaned that and still same problem. I for sure know the left side is bad but still not sure about the right since the lines are still there.
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      the "corner cable test" is done with all other cables connected. Sorry but I can't follow your description of what's what. Pictures might help.
                                      Having said that, the "hot" test is usually a sign of "bad"... but as I indicated, you have something going on in the right side.
                                      • nwcs
                                        • Dec 2015
                                        • 311
                                        • usa
                                        I have come to the conclusion that panel is not repairable at all. I may go further but it is a lot of work for me to do and run a store.
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
                                        • zoontz
                                          SHARP LC-70UD27U black and white lines
                                          by zoontz
                                          Wondering if anyone has addressed an issue with the SHARP 70” LC-70UD27U having thin black and white lines running from left to right horizontally on the screen. I snagged this TV set from a neighbor since I have been successful in repairing numerous other TVs. I assume this probably happens to other TV sets and may have been addressed in another thread. If so please point me in the right direction.
                                          What I have tried so far.
                                          I have tested all HDMI inputs with the same results.
                                          I have checked for firmware updates.
                                          I have reset to factory settings.
                                          I have removed...
                                          07-09-2024, 05:50 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
                                        • jaco2d
                                          Sharp 50bj2ke horizontal lines
                                          by jaco2d
                                          This is only my seond post and so far i am very impressed with the forums.
                                          I have a Sharp 50bj2ke which is 6 month out of gaurantee and has devoloped horizontal lines, i have tried to research as much as possible but i am no further is diagnosing the issue. When i turn the tv on it works good with only a thin line right at the top of the screen which i could live with but after a couple hours of use the lines start to appear in the middle of the screen and now the bottom.
                                          The small white box thing in the pics is not the tv its a reflection from the window
                                          Any suggestions...
                                          11-01-2022, 04:45 PM
