rca rlded5078a-d
  • smuddge
    • Feb 2012
    • 96
    rca rlded5078a-d
    rca rlded5078a-d
    power comes on, no video at all.
    everywhere i read it is the power supply that is causing the issue here.
    I see shopjimmy has no power supplies.
    I don't trust ebay and none are there either right now.
    power supply model - ay128d-4sf11
    no visible damage anywhere on the board.
    this is the 3rd rca rlded5078a-d that i seen with the same problem.
    this one was given to me so I would like to see if i can fix it.
  • CapLeaker
    Leaking Member
    • 8324
    Re: rca rlded5078a-d
    Does it have audio? How about video if you shine a flashlight into the screen? I wonder if the backlight come on and turns off again. You would have to upload some pics and do some measurements to find out
    • smuddge
      • Feb 2012
      • 96
      No back light at all. doesn't flash on even for a second. Will check for audio but I don't think it has audio either. just powers on blue light on the front.
      Tcon? mainboard? I will take whatever pics you want let me know.
      no visable damage to any components.
      • CapLeaker
        Leaking Member
        • 8324
        upload some pictures so we can see
        • smuddge
          • Feb 2012
          • 96
          you want pictures of boards?
          • CapLeaker
            Leaking Member
            • 8324
            Hi res pictures of the boards, yes.
            • R_J
              • 9588
              Have you checked the voltage going to the backlight led's?
              • smuddge
                • Feb 2012
                • 96
                here are the pics as requested.
                I have not tested anything.
                still learning so i am not sure what i should be looking at here.
                tell me what and where to measure and i will see what i can find out.
                appreciate this help.
                you guys are all really helpful!!
                • CapLeaker
                  Leaking Member
                  • 8324
                  On the power supply I don't see a pinout. Is it maybe printed on the back of the board?
                  Can we see the whole back of the TV with all boards connected?
                  First off I'd be probing the voltage rails on the PSU to see if everything is there. Also check the backlight voltage with. You can also check the power and fuses on the T-con.
                  • smuddge
                    • Feb 2012
                    • 96
                    full pic of all boards
                    bottom of power supply board
                    • CapLeaker
                      Leaking Member
                      • 8324
                      Let's check the PSU. Disconnect everything from the PSU but the backlight. Take a 1k ohm resistor and jump 5vsb to PSON and Another 1k ohm resistor from 5vsb to BLon and plug it in. Everything should be alive and the backlight should be on. Measure all DC voltage rails and the DC voltages on the backlight connector.
                      • smuddge
                        • Feb 2012
                        • 96
                        so let me verify. I am taking 2 1k resistors from +5vbs and running one of them to blon and one to pson.
                        only power and backlight cables connected?
                        If this is correct I did it and I still get nothing for display at all.
                        screen is black. can hear buzzing from power supply but nothing on the screen whatsoever.
                        • CapLeaker
                          Leaking Member
                          • 8324
                          That's correct. You should see that all the voltage rails on the PSU are up and running. ALso the backlight if you have it plugged in should be on. The main board is disconnected.
                          Maybe you could post another pic from the PSU with the pin out without that foil? Can't see it good enough.
                          • smuddge
                            • Feb 2012
                            • 96
                            ok here are all measurements i labeled all the connections 1-4
                            and this is the corresponding voltages for each
                            I added another full pic of the power supply board too.
                            thanks for all your help so far very much appreciated.
                            I am still very green when it comes to this just in case i sound like a moron.
                            connector 1
                            pin 1 11.75
                            pin 2 11.75
                            pin 3 0
                            pin 4 0
                            pin 5 0
                            pin 6 5.04
                            pin 7 5.04
                            pin 8 5.04
                            pin 9 4.95
                            pin 10 5.04
                            pin 11 5.04
                            pin 12 0
                            pin 13 0
                            connector 4
                            pin 1 .69
                            pin 2 0
                            pin 3 0
                            pin 4 0
                            pin 5 0
                            pin 6 0
                            pin 7 0
                            pin 8 0
                            pin 9 0
                            pin 10 0
                            connector 2
                            pin 1 23
                            pin 2 23
                            pin 3 0
                            pin 4 0
                            connector 3
                            pin 1 5
                            pin 2 0
                            pin 3 0
                            pin 4 0
                            • CapLeaker
                              Leaking Member
                              • 8324
                              So far you are doing pretty good! So don't worry about being a bit green behind the ears...
                              Create a temporary short between BLon and ADJ, see what that does. 0V on the ADJ wont work.
                              • smuddge
                                • Feb 2012
                                • 96
                                with the resistor still in place and shorting blon and adj I still get nothing coming on at all.
                                  What DCV do you get between the two legs of the main filter cap (the big long cap laying on its side) when PS-ON is applied? It should have >360VDC for the LED backlights driver to operate.
                                  • smuddge
                                    • Feb 2012
                                    • 96
                                    380v across the large cap
                                    • CapLeaker
                                      Leaking Member
                                      • 8324
                                      I see all the voltages are there, just nothing is coming out from the LED driver circuit of the PSU.
                                      I found a PSU at tvparts.ca its a bit pricey.
                                      Anyway... I guess you are down to check the LED driver. So check the 2 resistors, the 2 capacitors and the 4 diodes etc. Hopefully the transformers are not open. If you get to a part that is shorted in circuit, take it out and measure it again out of circuit.
                                        http://www.shopjimmy.com/proscan-ay1...upply-unit.htm
                                        I will need the good quality pictures like the one by SJ to be able to trace out the connections in the LED Driver circuits.
                                        • Joel Ohana
                                          Lenovo IdeaPad 3 15IAU7 that suffered water damage
                                          by Joel Ohana
                                          I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
                                          Symptoms:
                                          • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
                                          • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
                                          What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
                                          03-06-2025, 11:25 AM
                                        • azozexd
                                          Need help hp 725 g3 liquid damage
                                          by azozexd
                                          Hello freind i have hp elitebook 725 g3 White liquide damage
                                          after cleaning the board i find à damage resistor white no value i test it not reading in multimeter
                                          could some one tell me the value of this resistor
                                          Thank you...
                                          12-15-2024, 06:01 PM
                                        • mon2
                                          A1466 Macbook Air (Liquid damage repair)
                                          by mon2
                                          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                          Macbook AIR Model A1466 Diagnostic 09-01-2021
                                          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                          Problems & Resolutions
                                          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                          09-01-2021, 09:31 AM
                                        • rtstorm
                                          HP EliteBook 840 G8 water damage - identify component
                                          by rtstorm
                                          Hello, i got an HP EliteBook 840 G8 that has water damage, and i found this component has damage on it U60600. What is that component? I have schematics and boardview and the par no is:
                                          SINERGY_SYV128RAC_QFN_20P i cannot fount it anywhere. Is this component have some other name?
                                          Here is schematics + boardview...
                                          09-18-2024, 05:36 PM
                                        • Jenzo
                                          MacBook A1989 overheating after liquid damage
                                          by Jenzo
                                          Hey everyone,
                                          Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
                                          I can't figure out how...
                                          05-13-2023, 07:58 AM
