rca rlded5078a-d
  • dpcookson
    • Sep 2015
    • 11
    Re: rca rlded5078a-d
    Update; I was able to use an old ATX power supply to supply each LED with 3.3V.
    6 of the LEDs were burnt out, the odd part is that the first LED on all 5 strips were burnt out plus 1 part way into one of the strips. Would this indicate an over voltage problem?
      Since you did get high Voltage reading for seconds, it is telling me that the circuit is not dead.
        You should put a current limiter resistor when testing the LED.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8326
          GND lead of the DMM was on the GND circuit of the board. On power up, the voltage at the LED connector started at +0.69V then about 3-4 seconds later it "dropped" to -394V, then returned to +0.69V. With the unit powered off there is 0V at the LED connector. I suppose it doesn't matter which side of the LED circuit is positive or negative, as long as the LEDs polarity matches.
          I realize that an LED is a diode but maybe I was checking them wrong with my meter, if you look at my previous posted pictures, I was connecting my leads to each copper "dot" on both sides of an LED. I tried reversing the leads but came up with an open circuit on the few random LEDs I tested, makes me think I am doing something wrong, that or every LED is "NFG".
          That mean the LED driver is working O.k. (high voltage spike), however I think you have probed it not correctly... but that doesn't matter. Main thing is the circuit is working.
          It doesn't surprise me that there may be 5 LED's in a row bad. Most of the time the backlight of the panel was set on 100% and that does shorten the LED life. Set it back to 60 to 75% and the LED's in the panels are going to last much longer.
          x 2
          x 3 and that one is important! LED's supposed to be current limited not voltage limited. Even so you can voltage limit the LED, that is not correct way to do it.
          Anyway... You have way to many LED's out so you would have to find replacement LED's or harvest some used LED's from a different TV.
          • 2cams70
            • Sep 2015
            Looks like these critters might suit:
            http://www.ebay.com/itm/New-LED-TV-B...item3ab172d4f9
            Seems to be a design or LED quality problem with this TV though for it to be such a common issue. Any ideas about the root cause and modifications that might stop this in future - other than turning down the brightness. Add resistor in series with LED's perhaps?
            • smuddge
              • Feb 2012
              • 96
              just for anyone else reading this. it is indeed the leds that were burnt.
              I tested and had 1 that had a short and 1 that was burnt out.
              changed them both with some spares I had from a bad samsung and voila.
              back to working.
              i changed them with a heat gun but the one with the short still wouldn't work so I ended up just cutting a part of the samsung strip and wiring it in and taping it down so it was in the right position.
              let it run over night to make sure it would last and 12 hours later still going strong no issues.
              thanks again to this forum and its members for helping me and saving another one from the dump.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8326
                Nice follow up! Thanks!
                  Thanks for the follow-up.
                  You should also turn down the backlights level as much as you can, that will extend the life of the LEDs.
                  • ajal14
                    • Jul 2014
                    • 7
                    • canada
                    #49
                    hi, I have the same issue on my TV , the same modele as your tv rca rlded5078a-d. Did you fix yours so you may help me with mine. I have doubt on the IC LED DRIVER , BD9211F,nothing coming out from it but it has the 11.8volts at pin 1.
                    • ajal14
                      • Jul 2014
                      • 7
                      • canada
                      #50
                      hi, I have the same issue on my TV , the same modele as your tv. Did you fix yours so you may help me with mine. I have doubt on the IC LED DRIVER , BD9211F,nothing coming out from it but it has the 11.8volts at pin 1.
                      • Joel Ohana
                        Lenovo IdeaPad 3 15IAU7 that suffered water damage
                        by Joel Ohana
                        I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
                        Symptoms:
                        • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
                        • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
                        What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
                        03-06-2025, 11:25 AM
                      • azozexd
                        Need help hp 725 g3 liquid damage
                        by azozexd
                        Hello freind i have hp elitebook 725 g3 White liquide damage
                        after cleaning the board i find à damage resistor white no value i test it not reading in multimeter
                        could some one tell me the value of this resistor
                        Thank you...
                        12-15-2024, 06:01 PM
                      • mon2
                        A1466 Macbook Air (Liquid damage repair)
                        by mon2
                        Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                        Macbook AIR Model A1466 Diagnostic 09-01-2021
                        Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                        Problems & Resolutions
                        1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                        09-01-2021, 09:31 AM
                      • rtstorm
                        HP EliteBook 840 G8 water damage - identify component
                        by rtstorm
                        Hello, i got an HP EliteBook 840 G8 that has water damage, and i found this component has damage on it U60600. What is that component? I have schematics and boardview and the par no is:
                        SINERGY_SYV128RAC_QFN_20P i cannot fount it anywhere. Is this component have some other name?
                        Here is schematics + boardview...
                        09-18-2024, 05:36 PM
                      • Jenzo
                        MacBook A1989 overheating after liquid damage
                        by Jenzo
                        Hey everyone,
                        Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
                        I can't figure out how...
                        05-13-2023, 07:58 AM
