help me to test transfromer?
+ More Options
Posts
  • mattstolte
    • Dec 2013
    • 612
    • usa
    im trying to find which transformer is bad can anyone tell me how to test these? I was told to Ohm out the secondary (small windings) of each transformer to find the one that reads >0
    but I don't know what windings are ive never learned how to test a transformer please help with pictures also if you can thanks
  • johnboy1313
    • Nov 2012
    • 1959
    Re: help me to test transfromer?
    http://lmgtfy.com/?q=how+to+test+a+t...mer+with+a+dmm
      • 30934
      those transformers have cracked soder joints.
      • R_J
        • 9515
        Measure the secondary of each transformer (circled in yellow) It should read around 900 - 1100 ohms, but each of the 4 transformers should read the same if one is lower or higher it is most likely the bad one.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          Are these transformers to CCFL backlight to a Screen or monitor?
          • mattstolte
            • Dec 2013
            • 612
            • usa
            these are for a 32 inch emerson lcd, I put my meter on 200k ohm they all read 112-115 the tv turns on them after 30 seconds shuts down
            • SteveNielsen
              Retired Tech
              • 2327
              I don't see any cracked solder joints from the pics. Please point them out for us.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                You can tell which is bad when you first turn on. It will be the one going to the backlight that does not light. Are you sure you do not have a bad backlight? That can be check by opening the panel looking at the one that does not light and then changing it with one that lights. Usually the input voltage is check on these transformers as the input voltage is small compared to the output voltage.
                • johnboy1313
                  • Nov 2012
                  • 1959
                  Have you checked the wiring to the ccfl's?
                    • 30934
                    probably more - the blured pic dont help!
                    • CAIIIA
                      • Mar 2012
                      • 14
                      • Russia
                      Please use translator. this my post. http://televid-sib.ru/index.php?topic=4798.0
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        I consider it to be inconclusive. It is just too blurred to tell. Nothing looks shiny where it is that far out of focus.
                        • CAIIIA
                          • Mar 2012
                          • 14
                          • Russia
                          Ok. Add full picture.
                          • R_J
                            • 9515
                            try only hooking up one ccfl at a time, disconnect lamps 2,3, & 4 and see if the # 1 light flashes on. then disconnect #1 and connect #2, then repeat with lamp 3 & 4. if a lamp does not light (for example #2) connect #2 lamp to transfomer #1 or #3 and see if it lights.
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              So I do not know if op has a scope, etc. to measure 800 volt P to P on 100 usec div.
                              • the_rem
                                Unknown transformer : how to find a good replacement part ?
                                by the_rem
                                Hello guys,
                                I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                04-23-2025, 01:48 AM
                              • BlueMonsoon
                                How to find the spec of this TEI-16760-01-08C transformer.
                                by BlueMonsoon
                                Hi, I want to replace a transformer in a motor cycle battery and float charger, but I can't find any info or the spec of the transformer, in order to start looking.
                                The number on the transformer is, TEI-16760-01-08C. The info on the charger is input, 220-240V 50hz 0.085A output 12V 0.8A.
                                Does anyone know where I could find a replacement for this? Thanks.
                                01-10-2022, 08:30 AM
                              • bauto601
                                KDM 480W PSU upgrade succes! (opinions?)
                                by bauto601
                                Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                A "nice" YoungYear unit? - Badcaps
                                The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                12-26-2023, 03:05 PM
                              • caseyjay_48
                                Sony KDL-46BX450 Inverter Troubleshoot Logic
                                by caseyjay_48
                                I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                09-23-2022, 08:08 PM
                              • chth96
                                How Can I test PWM DM0365R?
                                by chth96
                                Hello
                                I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                                So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                                I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                                I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                                06-18-2025, 04:14 PM
