Sharp LC-40LE550U. Green light, but no picture/audio
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    This one came from a small lot of Sharp sets I got awhile back. I've noticed virtually all the Sharp sets were OK, but they are very finicky about damaged screens and powering on.
    Wanted to ask about this one, because it's different than the larger sets. It has a small power LED, and that seems to be the indicator (as opposed to the V light on the larger sets).
    When I power on, the led turns green, and stays solid. I also have light from the mainboard optical out. The IR appears to respond, as I can turn the set on/off from remote. However, it seems "blocked" somehow as no picture or sound of any sort.
    Got the SM, and it looks like the panel could again be the culprit, but I'd like to take the boards as tested as I can make them.
    The screen on this set isn't badly damage, and all the rest seems in good shape. Could a blown TCON fuse be causing this? Is it worth it to hookup something to the optical out to see if sound comes through?
    Re: Sharp LC-40LE550U. Green light, but no picture/audio
    Do you have backlights and the backlights are staying on but no image on the screen?
    Pictures of the TV?
    • tucocaps
      • Apr 2013
      • 331
      • United Stated
      bud,
      no backlights. i guess i could take a picture, but it would just be the black screen.
        Show us the pictures of the back side of the TV then, so we can see what boards you have in your TV.
        • tucocaps
          • Apr 2013
          • 331
          • United Stated
          Bud,
          Took cover off mainboard , and pictures of each board. Thanks!
            So what DCV do you have on all the pins (EXCEPT GND) of the connector CN201 when TV is OFF and when the power switch is activated?
            Pictures provided by SHOPJIMMY.
            http://www.shopjimmy.com/catalogsear...rp+LC-40LE550U
            • updateemu
              • Mar 2014
              • 10
              • usa
              I have one with no backlight. Sound and pic with flashlight. There are 2 connectors going to the LEDs CN202 (yellow) CN203 (black) Measuring to ground pin 1 of CN202 is 320V and the rest 280V. CN203 pins 1 and 2 180V, 2 and 4 120v and 0v on pin 5. Have heard of some being bad solder connections on LED driver boards in display. Any suggestions?
              • updateemu
                • Mar 2014
                • 10
                • usa
                It was bad solder connections on the LED board. Resolder the connectors to the board. You will have to remover the display from the front.
                • fenguc
                  • Feb 2016
                  • 4
                  • us
                  mine was dad last week without picture and without sound. Remote can turn on TV and indicator is without any blinking. What is next step that I could check?
                  • fenguc
                    • Feb 2016
                    • 4
                    • us
                    I mean the TV is not working last week.
                      Upload good clear pictures of the whole back side of the board.
                      is your board the EXACT same board as shown in my post #6.
                      OP never have follow through on the request in post 6 so you need to report the DCV readings.
                      You do have meter and know how to use it, right?
                      • fenguc
                        • Feb 2016
                        • 4
                        • us
                        @budm Many thanks.
                        The power supply board is same (1P-0132X01-1010), after I open TV back cover. I also checked TV last night with little light. The TV can play video from USB memory with sound, and very weak images only seen with flashligh.
                        It seems back light is broken. I would like to check voltage as you suggested. But I am totally not familiar with the TV, only with electronic knowledge from high school. Could you provide any youtube video that I can follow? Thanks a lot.
                        • fenguc
                          • Feb 2016
                          • 4
                          • us
                          I measured voltages with connected LED strips as followed
                          CN202 (yellow)
                          pin1: 338
                          pin2: 281
                          pin3: 282
                          pin4: 228
                          pin5: 227
                          CN203 (black)
                          pin1: 172
                          pin2: 172
                          pin3: 119
                          pin4: 119
                          pin5: 0
                          Without connection with LED strip as followed,
                          CN202 (yellow)
                          pin1: 338
                          pin2: 0
                          pin3: 0
                          pin4: 0
                          pin5: 0
                          CN203 (black)
                          pin1: 0
                          pin2: 0
                          pin3: 0
                          pin4: 0
                          pin5: 0
                          Any suggestions? Thanks a lot.
                          • MOSSEP
                            Monitor Audio RSW12 - Green light, but no sound
                            by MOSSEP
                            Hi
                            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                            I have already tried replacing all of the...
                            01-26-2025, 08:33 AM
                          • MOSSEP
                            Monitor Audio RSW12 - Green light but no audio
                            by MOSSEP
                            Hi
                            01-26-2025, 08:18 AM
                          • lcdcaps1
                            820-2610-A Sys onewire help, no green light. Please help from the gurus
                            by lcdcaps1
                            Hi
                            I have an 820-2610-A motherboard that has no green light.
                            I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                            From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                            The sys onewire circuit on this model and others is more involved
                            I was hoping if anyone knows about this and how it works, can reply and let me know
                            I know this is an old model but I am sure there are people who still works on these or knows about them
                            I get 1.1v on the C7771 capacitor and will replace...
                            11-06-2023, 01:28 PM
                          • PNI E.
                            tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                            by PNI E.
                            hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                            02-20-2025, 08:36 AM
                          • roy.zhero
                            Sharp LC50LE752E no picture and backlight, indicator light is lit
                            by roy.zhero
                            I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
                            When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
                            When I hold the force-on-combination it will turn on. It then shows a perfect...
                            09-20-2020, 01:57 PM
