Re: VIZIO E470VA Dead
[QUOTE=budm;580951]"It came right up to 5.09 v right away and then dissipated down to 1V " OK, that is not normal, the STANDBY 5.2V is an always on power supply that is running 24/7 hwne you have the TV plugged into the outlet. So it is either there is problem in the standby pwoer supply or the main board is load the standby power supply.
You can try this quick test, unplug the TV from the outlet, then heat that section I marked with hair dryer for 2~3 minutes, then plug the TV in and monitor the 5.2VDC pin, then turn the TV and see if the 5.2V will stay on at 5.2VDC. When STBY power supply drops out, every thing will drop out with it.
Picture provided by shopjimmy.[/QUOTE
Hello Budm
I have same model vizio tv, but my power supply is not the same shown in the picture.... my one is vizio 92424ABV.... 715G4069-P01-W30-003M
the problem I have is that the tv does not present logo power and does not tunr on... when measuring voltages everything is present at power supply (24, 12 volts), but 5 volts terminal is about 2.6.... if i disconnect the main board the 5 volts terminal shows 5.1 and 24, 12 dissapear.... heating up the start up whe only see logo starting for a very short period and very dimm when connecting the set.... what could be wrong with this unit?
Hello Budm
