Vizio vp422 wont power up
  • chrisman183
    • Aug 2015
    • 10
    • usa
    Hey guys, I'm extremely new (first day). so, I had a power surge a couple weeks ago, it took out my wireless router and also my 42" vizio.
    It's a VP422 HDTV10A.
    It has no amber/white light at all. Completely dead, I can see a small green LED through the back panel however. If I unplug it, and plug it back in, the screen flashes white like it's trying to come on, and the amber light comes on for a half a second, then it is again completely dead. the power button doesn't work, only unplugging and then re-plugging(?). I was hoping this is just the power supply? The only thing that got fried on my router was the power supply transformer.
    Anyway I did read about a "2 seconds to black" issue that sounded similar, but after reading about it a little, it sounds a bit different....
    Any thoughts/suggestions?
    Thanks for any help guys...
  • chrisman183
    • Aug 2015
    • 10
    • usa
    Re: Vizio vp422 wont power up
    anything?
    I've gotten it apart and going through the T/S guides, but nothing is based on the specific tv i have...
    • TVRepairNoobie
      • Feb 2015
      • 158
      How about from this list?
      http://www.toms-service-manuals.com/...&Search=Submit
      • TVRepairNoobie
        • Feb 2015
        • 158
        Upload clear pictures of the boards from your TV.
        • TVRepairNoobie
          • Feb 2015
          • 158
          Check the fuses to see if its dead.
          • chrisman183
            • Aug 2015
            • 10
            • usa
            yes I had been looking at that guide, thank you. I'll get some pictures and let you know what the results are from checking it soon.
            • chrisman183
              • Aug 2015
              • 10
              • usa
              All the fuses I could readily identify are good.
              • chrisman183
                • Aug 2015
                • 10
                • usa
                Have to do these 1 at a time apparently...
                • chrisman183
                  • Aug 2015
                  • 10
                  • usa
                  3rd one
                  • chrisman183
                    • Aug 2015
                    • 10
                    • usa
                    Ok so I finally checked all the voltages at the test points on the power supply board. They are all good! I was surprised. So. What could I look at next? This is the voltages I got and what they're supposed to be.
                    Thanks for your help. I was hoping it was the P/S board... :-(
                    • chrisman183
                      • Aug 2015
                      • 10
                      • usa
                      Anything? Don't know what to look at anymore basically. Could the control module board be bad? Is there anything to check there?
                      • chrisman183
                        • Aug 2015
                        • 10
                        • usa
                        For sale: TV described above. Make offer. 😆 thanks anyway guys
                        • Toasty
                          • Jul 2007
                          • 4171
                          Thread necro here:
                          Found same problem today on same model.
                          Problem was OPEN cap C8002, 22uF / 450v, 16 x 30mm just below central heatsink. In the picture in post 7, it is left of the smallest of the 4 transformers in a row, T8001, and right of fuse F8002.
                          Also, several of the small caps (5mm) are all over the place in ESR, so they'll be going too.
                          Yes, set is a bit long in the tooth, but the client doesn't have a lot of money to spend.
                          Cheers!
                          T
                          veritas odium parit
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • double_DD
                            Why does my ISP router hate my "homemade" power supply??
                            by double_DD
                            It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                            So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                            For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                            07-12-2025, 03:09 AM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
