Sharp LC-C52700UN OPC Blinking.
  • Ltank
    • Jun 2013
    • 776
    The Power an OPC led flash twice the pauses and same sequence over and over. I can jumper the Stby 5vdc to P.S.-ON and PNL-POW.
    P.S. Stays on and I get 136vdc to LA1 and LA2 connectors on the A side (colored wires) 0vdc K side Cathode. I get no backlight. Trying to confirm the P.S. is OK. I get the 13vdc, 5vdc and PNL 12vdc. I would say the P.S. is fine. But wouldn't I get a backlight? I guess theM.B. is toast. I got one from a place online but got the same OPC Blinking error. So I thought perhaps I had a bad P.S. but it checks fine. M.B. or perhaps TCon?
    Re: Sharp LC-C52700UN OPC Blinking.
    Are you getting >360VDC between the two legs of the MAIN FILTER caps when you force on the power supply?
    http://www.shopjimmy.com/catalogsear...rp+LC-C52700UN
    • Ltank
      • Jun 2013
      • 776
      Yea it's fine. I had confirmed my voltages as indicated. The voltage was not labeled for the led connectors but it was 136vdc.
      No backlight though. Dark screen putting a flashlight on screen did no show any menu or anything.
      • R_J
        • 9550
        If its the same as the LC-52LE700UN, Tried uploading the manual but got this error.
        Looks like D3.3 volts could be missing.
          Just to see, keep the meter on the LED connector, then turn the TV on to see if the meter will show the DCV jump up a lot higher than 136VDC and then settle back down to 136VDC.
          • Ltank
            • Jun 2013
            • 776
            I saw that about the 3.3vdc. There is no 3.3vdc listed on the P.S. oututs. All listed voltages are there. Including the 136vdc to the LED backlighting. I will set my meter to capture peak voltage and turn the set on. I will test it Monday morning. Thanks.
            • R_J
              • 9550
              Looks like the D3.3 supply is on the main board, It comes from ur13 volts into pin (2) of ic9606 and comes out pin (3) D3.3v
              • bajdik
                Sharp LC-40LE830E white blinking after wallplug is off
                by bajdik
                Hello, on Sharp LC-40LE830E is everything OK. Working great. If I put the 230 V off and on again, it just blinking white standby LED. I can power on only via VOL- and CH+ and POWER button on TV. After that, I can power off and power on again without problem (by buttons or remote control) until the 230 V is connected. If i put the plug off and on again, just white standby LED blinking. TV needs three button starting again.. On the first look, the backlight looks great, no darker or lighter spots. Any idea what is wrong?
                07-21-2023, 09:05 AM
              • cm0002
                Sharp LC-55N7000U 1 long 5 short blinking, no display
                by cm0002
                I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
                Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
                I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
                06-19-2023, 06:21 PM
              • Charrlie
                Sharp Lc-70le734u blinking 2 long 5 short
                by Charrlie
                Just picked up this sharp tv not too long ago and it started not wanting to start the other day, giving me the notorious 2 long-5 short blink pattern indicating a power issue. I was able to force start it a handful of times (once the tv has fired up it has no issue running for 5+ hours). But now as of yesterday, no matter what I try to do button combination wise, I just receive the same blinking code.
                So I busted into it and have done the following:
                -Removed the power board and inspected for any bad caps, burn spots etc. Do not see any instances of such ...
                07-07-2022, 02:02 PM
              • olegeisler
                SHARP AQUOS LC-70LE836S only blinking - freebie
                by olegeisler
                Got this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
                Symptoms :
                When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
                A press on MENU as per the manual changes this to one short blink, one long and then repeats.
                Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
                As I see it mainboard has some kind of life, but does not...
                07-23-2022, 07:01 AM
              • YasaCh
                Sony kdl 40p5500 red light keeps blinking 3 times
                by YasaCh
                Hello...
                my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                i opened the back cover no sign of damage on the powery suply or motherboard
                when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                07-07-2025, 11:53 AM
