Help with Samsung Un46eh5300. No picture. Backlight on
  • Morocck119
    • Jul 2015
    • 8
    • United states
    Hello all, this is my first thread and honestly I'm stumped on this TV repair. I picked it up for cheap because the owner said there was no picture (looks like the set has never been opened previously) so I dug in and to my surprise the TCON board had a blown IC chip in it. So I though "ah there's the problem" so I ordered a replacement and plugged it in annnd I still have no picture. The back lights stay on and I can hear the menu. So I did some more research and found that my EEPROM chip may need reset due to the blown IC but I cannot find the EEPROM despite searching Google for two days. My main board model is BN94-O5750Q. I really do appreciate any and all help. Thank you
    Re: Help with Samsung Un46eh5300. No picture. Backlight on
    Which IC on the T-CON board that is blown?
    How about the pictures of the boards and the whole back side of the TV?
    I have never heard of EEPROM of the main board has to be reset due to blown IC on the T-CON board.
    • Morocck119
      • Jul 2015
      • 8
      • United states
      The EEPROM is on the TCON board? Here's some pictures of the boards. Included two pictures of the bad TCON
      Edit: the blown IC has this written on it :17939A...H32090R.
        "The EEPROM is on the TCON board? Here's some pictures of the boards. Included two pictures of the bad TCON" I do not know since you said the EEPROM needs to be reset, I would assume the EEPROM on the main board. Where did you get that info from?
          So you install the new T-CON board? Is it a KNOWN GOOD board?
          • Morocck119
            • Jul 2015
            • 8
            • United states
            It was pulled from a unit that had a cracked screen. And it came in antistatic packaging so it should be okay.
            The seller says the board has been tested and works
            • Hamie
              • Apr 2014
              • 1383
              They all say "the board has been tested and it works". Most of the time this is complete bull.
              You'll need to check the t-con voltages.
              Firstly the fuse, does it get 12v on either end of it?
              If it does check AVDD test point and see if it gets roughy 15v
              • Hamie
                • Apr 2014
                • 1383
                Finally if the fuse is open! DONT JUMP IT! Or you'll damage your panel.
                • Morocck119
                  • Jul 2015
                  • 8
                  • United states
                  Okay fuse show continuity and when powered on its at 12.8 volts. Looking for the AVDD now
                  Edit: there seems to be a really faint clicking by the tcon board I can't pinpoint exactly where its coming from on the board in fear of the side of my fave meeting 12v lol
                  • Morocck119
                    • Jul 2015
                    • 8
                    • United states
                    Ahhhh, found where the clicking is coming from.....doesn't look too good :/
                    Looks like this caused the IC on TCON to pop...maybe try and clean it off with rubbing alcohol and see what I can do.
                    • Hamie
                      • Apr 2014
                      • 1383
                      That not good, the panel is gone I'm afraid.
                      • Morocck119
                        • Jul 2015
                        • 8
                        • United states
                        Yea, well thank you both for helping me with this. I'll try the rubbing alcohol route as a last resort but it is looking grim. I'll post if anything changes or if I have another TV I'm attempting to fix and I'm stuck. (Next one is a RPTV convergence issue in a week or so)
                        • CapLeaker
                          Leaking Member
                          • 8159
                          someone cleaned the screen and the water ran down. not good!
                          • Jmcmunn
                            • Aug 2015
                            Hi,I'm also new to forum.i have the same problem,no picture but have sound.i took the back off and see the panels,but do not see anything out of the ordinary,,,where should I start?thanks
                              09-07-2024, 05:50 AM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • JJAAMM
                              by JJAAMM
                              Problem
                              07-06-2023, 06:01 AM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • cheeky2
                              Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                              by cheeky2
                              This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                              I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                              Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                              06-15-2025, 05:12 AM
