LG 32LD450 shuts off after 15-25 seconds
    replied
    Re: LG 32LD450 shuts off after 15-25 seconds
    OK, so we now know that the pfc is working but some how the Power ON (PS-ON) disappear and causes PFC and the rest of the switched power supply to turn off, but the standby 3.3V is always present, so something on the main board is going bad, it can be caps, IC, bad solder joints, etc.
    You should also look to see if the INVR ON (BL-ON) also disappear or not too.
  • MisterD
    replied
    Deleted repeated reply.
  • MisterD
    replied
    Sorry Bud my meter was set on AC, measured across main filter caps got 360 VDC while set was on and working, It was on about 15 mins this time and shut down with flashing red light, while shut down voltage across main caps is 168 VDC.
    After unplugging and letting caps bleed down to 30 volts, plugged back in and got same 168 VDC while off and 360 VDC while on and working.
    replied
    "Voltage across main caps flucuates from 781 down to 481 V AC while set is on and working, then drops to 222V AC when backlights are flickering, set shuts down then voltage across main caps is 368V AC, power light is flashing red like a car turn signal everytime it shuts down, but I can power right back on and it may last only 15 secs to several minutes depending on how long it was left off. Any help is appreciated" You need to verify the DCV between the two legs of the main filter cap to see if the PFC Voltage circuit is working or not when TV is turned on. The Voltages you report are not right. Make sure to set the meter to DCV and measure right between the legs of the cap.
  • MisterD
    replied
    Here are some pictures of the boards and a drawing of the main rail connector on the power supply with voltages I read with volt meter, sorry but my camera will not take good close ups. The Brown colored wire is the power on 3.3VDC
    Thanks in advance, your help is apprecitated
    I hope budm will chime in, he is always very helpful.
  • MisterD
    replied
    The mainboard rail connector is Not labeled PSON but is actually labeled as power on, all voltages on the ps rail connector are normal As far as i know and all voltages drop to zero when the set shuts down, Except there are 4 pins with 3.4 volts and this voltage remains the same even when it shuts down.
    Backlights either flicker or flash off then back on 3 to 4 times right before it shuts down.
    Also this TV stayed on this time with the back off for about 20-25 minutes before shutting down the first time then gradually had less time with each time I turned it back on, getting down to as low as only 15 seconds.
  • CapLeaker
    replied
    you got to figure out why your PSon signal disappears. No wonder the PSU is shutting down if there is no PSon voltage sent from the main board.
  • MisterD
    started a topic LG 32LD450 shuts off after 15-25 seconds
    The longer it sits off it may stay on longer, I have had it stay on up to 5 minutes after sitting several days unplugged, once it gets to the point where it only stays on 15 seconds it will shut down and go to flashing red light but can always be turned right back on and will go about 15 seconds every time.
    normal power when it is on has blue light, I did measure the power on (pson) voltage on ps board rail at 3.3v but once it shuts down the 3.3v is gone, could I take two AA batteries and wire in series to get 3 VDC, and hook to the 3.3 rail on ps board to see if it stays on and if it does would that indicate the main board is the problem? And ps board is good?
    Sorry my camera is not here at this time to take pics of boards.
    Thanks for all replies
  • Nagy Daniel
    Lowest possible resistance on laptop motherboard rail - Guide Table request
    by Nagy Daniel
    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
    So, I generated a table with AI so I can...
    03-04-2025, 08:24 AM
  • chaos-theory
    Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
    by chaos-theory
    I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
    Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
    03-14-2025, 05:37 PM
  • APOPAP
    Panasonic National NV-M3 VHS Camera shuts down after some seconds
    by APOPAP
    Hello everybody,
    First post here. I have been reading posts here for some time now, but today I made my first account and post.
    The same question is also posted on another site, here it is:
    Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
    I tried connecting it to a Computer PSU (12.7v) but I get battery error...
    08-25-2025, 10:12 AM
  • tec3000
    Sony LED 65X9005A shuts down after few seconds - looking for help
    by tec3000
    Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
    I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
    03-20-2024, 07:29 AM
  • solveit68
    Lenovo L580 20LW-0010GE shuts down after a few seconds
    by solveit68
    Hello together,
    I am hoping for some tips here to repair a notebook.
    The notebook has following issue:
    After starting the notebook it shut down after a few seconds.
    Sometimes it is possible to enter the bios but then after, another few seconds it shuts down also.
    The time until shutdown varies slightly.
    What I've tried so far:
    - cmos cleared
    - removed all components that are not essential for motherboard testing including keyboard and touchpad
    - ram exchanged
    - same behaviour with power supply or battery...
    07-21-2023, 01:04 PM
