Philips TVs From Hotels - 32HFL5763L/F7 and 32HFL5561D/27 - Finding SSBs (Main Boards
  • JDC
    • May 2015
    • 273
    Hello all. This is more of a rant than a cry for help. I recently picked up two Philips TVs that were apparently pulled non-working from a hotel (the HFL series are "hospitality" models, I learned). Both need main SSBs (main boards) in my opinion. This wouldn't be a big deal if it weren't for the difficulty in finding parts.
    For the 32HFL5763L/F7, the SSB can be taken out without removing the entire back. Seems user friendly; if it goes bad, get a replacement and slap it in. Makes sense in terms of warranty repair as well.
    The more I bang my head off the workbench, the more it seems these TVs weren't meant to be repaired by the general public. This is fine but as it stands I have two TVs that are going to head to the recycler. Something tells me that even if I find replacement SSBs for 50 bucks or less, it may not even be worth it.
    Rant over, I guess. For anyone interested in part numbers:
    32HFL5763L/F7
    SSB: 313928802831 Partial Part #:8802831
    32HFL5561D/27
    SSB: 313928801654 Partial Part #:153518
    I sent an email to an online retailer asking for help, once I get a response I'll post it. Thanks for reading.
  • JDC
    • May 2015
    • 273
    Re: Philips TVs From Hotels - 32HFL5763L/F7 and 32HFL5561D/27 - Finding SSBs (Main Bo
    Actually 32HFL5516D/27's actual board shows 3139 283 0173v1. So many numbers.
    • Shane711
      • Dec 2014
      • 493
      Same here, I got 4 of these Philips 32HFL5561D/27 from a motel. All of them seem to have a bad main board. I will remove the EEPROM, freeze it, copy it to a NEW EEPROM and if that doesn't fix it I will scrap them out. All the panels are good.
      • R_J
        • Jun 2012
        • 9625
        This may not apply in this situation,
        I worked on a couple Philips hotel sets a while back and they had a couple small boards connected to the main board that when disconected I was able to get the main tv working, the boards were used for the hotel to communicate with the tv's.
        If I remember the tv's would not turn on with that board connected.
        • tuner2000i
          Philips 65PUS8518/12 distorted image after main board replacement
          by tuner2000i
          hello everyone,
          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
          07-15-2025, 01:15 PM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • Henke
          Philips 55POS9002/12 - No PS_ON voltage from main board
          by Henke
          I wondering if there are some usual faults regarding the PS_ON signal from main board to PSU board?
          Where do i start looking?
          I have standby light and the PSU is working if i connect 3.3V to the PS_ON pin on the psu board....
          08-11-2024, 08:34 AM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
