LG 37lc55 turns on few minutes later screen goes out
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    #41
    Re: LG 37lc55 turns on few minutes later screen goes out
    Hmm strange wander what lg did there anyway. The panel is a AUO (junk) think its the same panel used in the one I have which is failed I will let you know on Monday if it is I would say panel failure.
    • Blueeyes
      • Jun 2015
      • 60
      • Uk
      #42
      Damn not good anyway to be 100% sure its panel failure? Would explain why even with new main board the problem persisted
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • frannyjunk
        Hisense 40H4F no backlight but turns off after splash screen
        by frannyjunk
        So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
        TIA.
        09-24-2025, 10:59 AM
      • Rav_tangle
        MacBook Pro 2011 turns on with keyboard light , screen dead
        by Rav_tangle
        Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
        I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
        Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
        is this...
        05-31-2024, 04:09 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • krige
        asus g750js ms1130c (203) turns on nothing on the screen
        by krige
        hi all i was wondering if you could help me troubleshoot this laptop. i bought the motherboard off eBay. it is used. i fitted the motherboard into the housing of the gaming casing and turned it on. nothing shows up on the screen. i checked the connectors and no missing connectors. i also removed the graphics card and nothing on the screen. i even reflashed the bios but still nothing on the screen. can it be a corrupt bios? i even used the HDMI port but it also shows nothing on screen. could this be broken screen or a dead ec chip?...
        03-22-2024, 04:59 AM
