Panasonic TH50PX60U Power Problem
  • pansatdishman
    • Jun 2013
    • 110
    hello i bought a Panasonic TH50PX60U its used and not working i was told it took a shock it has no lights or power and all the fuses on the power supply are not blown any suggestions?
    thanks
  • d2fx
    • May 2015
    • 24
    • french west indies
    Re: Panasonic TH50PX60U Power Problem
    hello
    do you have 5 volts stand by?
    if yes check the s and k boards (power switch-power led)
    many time I've see oxidation cut wire
    • pansatdishman
      • Jun 2013
      • 110
      how do i check that thanks?
      • CapLeaker
        Leaking Member
        • 8186
        Clear straight shots pictures would help... to point. Other than that, you need a multi meter to measure AC and DC voltages.
        • pansatdishman
          • Jun 2013
          • 110
          Here's a pic
          • pansatdishman
            • Jun 2013
            • 110
            any ideas?
            • Hamie
              • Apr 2014
              • 1383
              You'll need better pictures than that.
              One pic of the whole assembly.
              Then a picture of each board.
              • Hamie
                • Apr 2014
                • 1383
                double post
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Check those capacitors that have the shrunken sleeves as well, they might be bad, or deteriorated.
                  Muh-soggy-knee
                  • pansatdishman
                    • Jun 2013
                    • 110
                    Pictures and what do you mean by shrunken caps?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      The arent all these power boards seem to do it.
                      • pansatdishman
                        • Jun 2013
                        • 110
                        so how do i test it or what does it look like thanks
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          You need to test various voltages. Are you confident in doing that? Have you a digital test-meter?
                          (I suspect 'no' to be the answer to both questions, from your previous posts....)
                          Be aware, a Plasma TV set has very high currents and voltages sufficient to easily kill you if you don't know what you're doing.....
                          --Also that its easy to make faults worse/blow up more boards and components by incorrect service procedures....
                          A Plasma TV set is definitely NOT the thing to start out repairing if you have no previous experience of electronics.
                          I doubt there's any faulty caps, Panasonic used good quality ones. More likely a semiconductor/IGBT/MOSFET/etc has failed. Plasma sets can be problems for even experienced engineers--Particularly Panasonic ones.......
                          TELEFIX
                          • pansatdishman
                            • Jun 2013
                            • 110
                            yes i have a digital multimeter i measured voltages before and soldered capacitors before so where do i check for voltages and just ground of the tv frame?
                            • jlanius
                              • Jul 2015
                              • 8
                              FWIW I recently stripped a TH50PX60U, and have all of the boards on ebay, if you figure which is defective
                              • jtgamble89
                                • Mar 2015
                                • 4
                                I have the same TV and the same problem. So instead of making a new thread I'd like to ad on here and hopefully it will help the other gentleman out. I have attached the 10 blink before power button pressed flow chart from toms serice manuals. I have followed all directives on it and found myself at NO 14V at Pin1 of Connector P10 on the P-board. I would much rather find the exact fault instead of replacing the whole P-board, as I was trained to troubleshoot faults and replace components as part of my job in the Navy. If anyone on here could assist with the next steps in either halfsplitting/ troubleshooting the exact issue so that I may fix this I would be very appreciative. Thanks
                                • jtgamble89
                                  • Mar 2015
                                  • 4
                                  Also I have included a picture of the P-board. It looks as though maybe 2 of the three 220V/900microfarad capacitors at the top may be a bit heavy. not sure if they are bad, how to test, or if that is an issue regarding no 14V due to no schematic or more detailed troubleshooting guide.
                                  • pansatdishman
                                    • Jun 2013
                                    • 110
                                    hello its still dead no red light etc or anything i read this may be the dg board? would this cause this to have no power and no red light etc thanks?
                                    • theone111
                                      by theone111
                                      3. Problem: TV shuts down
                                      07-22-2024, 10:36 AM
                                    • Duranitron
                                      Asus x512dk rev 2.1 power on problem
                                      by Duranitron
                                      When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                                      Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                                      11-26-2024, 10:22 PM
                                    • EazyBone
                                      LG OLED55C9PUA power problem
                                      by EazyBone
                                      Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                                      Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                                      I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                                      The power supply to t con is different story.
                                      This...
                                      06-23-2023, 07:43 AM
                                    • Dr.d
                                      Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                      by Dr.d
                                      I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                      Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                      04-05-2024, 11:48 AM
                                      by sam_sam_sam
                                      03-31-2024, 02:12 PM
