42LG3000 solarisation, tcon or lcd faulty
  • london-freddie
    • May 2015
    • 472
    Help needed please, been given this faulty 42LG3000 that was going to landfill.
    TV all seems to work fine apart from picture
    when first switched on screen is white with a dark shadow around the edge after a few minutes warming up the picture comes on heavily solarised, menus also are same
    Removed and refitted lvds cable from main to tcon no change in picture
    Anyone experienced this before,
    I assume it must be mainboard, tcon or lcd panel, but which one
  • london-freddie
    • May 2015
    • 472
    Re: 42LG3000 solarisation, tcon or lcd faulty
    2 more pics
    • london-freddie
      • May 2015
      • 472
      did it wrong, try again
        Looks like two faults.
        The solarisation is a known fault due to AS15F (T-con IC failure) - easy to fix with the right equipment.
        However the white banding is likely to be a panel tab bond fault that may or may not be fixable.
        • london-freddie
          • May 2015
          • 472
          do you think its worth trying a replacement tcon board
          • london-freddie
            • May 2015
            • 472
            tv has been on for several hours now with a solarized picture, however picture is now flashing constantly from solarised to perfect picture every few seconds
            • london-freddie
              • May 2015
              • 472
              Tcon board replaced tv working fine now
                Thanks for the follow-up, I did not really expect that the banding was caused by bad T-CON, learning something new today.
                • Fly_Among_Stars
                  VIZIO E70-E3 Half picture with half TCON
                  by Fly_Among_Stars
                  I have a VIZIO E70-E3.
                  Symptoms: Black screen, no picture, but LED backlights are working.
                  I probed the power board and voltages are as listed on the board.
                  Main board appears fine, too.
                  I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                  There are two separate ribbon cables feeding the LCD.
                  If both are connected, the screen is black.
                  If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                  04-24-2023, 08:20 PM
                • iglitare
                  by iglitare
                  09-04-2025, 07:13 AM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
                • shelby5041
                  Samsung LCD TV no picture backlight on no 12v at tcon
                  by shelby5041
                  hi
                  i have a samsung lcd tv
                  it powers on with sound and backlight but no picture
                  all voltages from PS are good 12v 3.3v and 5v
                  whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
                  i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
                  no 12v at the tcon fuse
                  i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
                  the odds of having 2...
                  10-08-2021, 08:21 AM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
