Samsung LN55C650 Power Issue
  • Audioplus
    • Feb 2012
    • 157
    Hello
    I've read a lot about this model's power issue. Will shut down, maybe after a period of time it will power back up, maybe not. The question is this is not normally a power supply issue? Can someone confirm if it's a main board, invertor, T-Con or ?
    Thank you!
  • sordids999
    • May 2013
    • 2155
    Re: Samsung LN55C650 Power Issue
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Audioplus
      • Feb 2012
      • 157
      I think 3 are attached? Main, Power and back, anyone with any ideas? Don't see any badcaps on power board.
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Cookybaby
        Samsung UN60ES6500FXZA Power Supply Issue
        by Cookybaby
        Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
        I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
        Make: Samsung
        Model: UN60ES6500FXZA
        Power Supply P/N: BN44-00525A
        Symptoms: The TV was...
        08-20-2023, 12:26 PM
      • Drewwol11
        Samsung QN49Q70RAFXZA Power Cycling Issue
        by Drewwol11
        My Samsung TV display recently stopped working while I was playing PS4 (no storm or anything to indicate a power surge). I could still hear audio through the PS4 but no display. The TV kept trying to turn on but would turn off after a second or two.
        I tried the obvious troubleshooting steps like unplugging, replugging, trying different outlets and power cords with no luck. Someone on another forum suggested that it may be a power supply issue so I purchased a replacement power supply board but that did not help. I then disconnected the main board from the...
        08-31-2021, 09:32 AM
      • lp20th
        Samsung Plasma TV Power Supply Issue
        by lp20th
        I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
        11-28-2023, 10:28 AM
      • mrtek
        Samsung UN43NU6950FXZA No power
        by mrtek
        Hi
        Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
        Main fuse = OK
        Back light LED = OK. Power them with aux power source
        LED output = OK 156V
        I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
        Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
        07-20-2025, 08:06 PM
