lc60le751k blue power light only
    hi all just bought this tv
    i was wondering if you can help me
    the tv dont function light up or anything just a ble power light
    ive tested all voltages from power board to mainboard
    all seem correct all except the bl_on which reads 0.00v
    if i unplug the led connector from the power board i get the 3.5v on bl_on
    ive stripped tv panel and cant seem to find any broken burnt leds on the strips
    please help on this one
    Re: lc60le751k blue power light only
    Come'on you should know by now... Pics?
    So with all boards connected when attempting to power the set do you get any voltage at all to BL_ON?
      with everything connected i get no voltage on bl_on unless i disconnect the led connector from the the power board
      and then i get the 3.5v on bl_on
      ive tried to test the leds using multi meter cant get them to light up like i could with samsung leds
      all have a resistance reading of about 7.55
        Right so all power is present with LED's disconnected, All signals from main are good.
        Can only be a dead LED.
          signals from main board ???????
          if you mean all signals from power board to the main yes all except bl_on
          also on the led connector on the power board its states 117volts for each of the plus pins i can only read them at 86 volts
          any ideas
          also any ideas how to test this led strip please
            No BL_ON comes from the mainboard to the PSU. Same as PS_ON.
            Get us some pics
              cant at present mate as im not with tv but there is nothing visible on the boards at all
              ps_on voltage is present
              can i just upload [pics stock from the net will this help
                "also on the led connector on the power board its states 117volts for each of the plus pins i can only read them at 86 volts" You should monitor the pins to see if it did jump up to more than 100V and then drops down to 86V.
                "if i unplug the led connector from the power board i get the 3.5v on bl_on" I s that the reading on the power supply board pin or on the main board pin? it looks it may have built-in pull up resistor on the power supply board for the BL-ON pin.
                The power supply is made by FSP :FSP202-4FS01
                http://www.fsp-group.com.tw/index.ph...roinfo&id=1717
                https://flattvparts.co.uk/sharp-lc-6...z-fsp202-4fs01
                  That does not look like a Sharp PSU, so I am guessing this TV is an OEM unit that Sharp have had made for themselves.
                  Yay - more re-badging crap for twice the price!
                  At least it's not a Vestel...!!
                    i tested from the mainboard mate
                      "all have a resistance reading of about 7.55" Is that the reading in OHMS, K Ohms, or M OHMS?
                        hi wreksta did you ever fix this tv or work out what was wrong ?
                        i have a chance of picking this one up with same fault,Red stand bye light is on when the plug is put in the mains . Then you press button and it goes blue as it should . And just stays blue
                          I had one
                          Stayed blue no response, sometimes went into standby using power button
                          changed motherboard and then it worked..
                          also had no response from the motherboard.
                            Did anyone find a solution on this one?
                            Have exactely the same problem as "wreksta".
                            As soon as I plug in the tv it turn on the Blue LED but nothing Moore.
                            Best regards, Pelle
