Un46c8000x
+ More Options
Posts
  • abdekader
    • Jul 2014
    • 73
    • Turkey
    Un46c8000x
    Hello
    I have UN46C8000X Samsung TV , I have short circuit in power supply "PSLF251B02A" in these components ( ICM891=G5207 , QM891=230N06L ,QM892=STD452S)
    we don't have these components in the Turkey So, I want datasheet to these component or power supply schematic or any information about these components please , I want your help friends
    Electronic Engineer from Syria,Aleppo
  • abdekader
    • Jul 2014
    • 73
    • Turkey
    Re: Un46c8000x
    no help , no one known information about these components ?
    • abdekader
      • Jul 2014
      • 73
      • Turkey
      Re: Un46c8000x
        Re: Un46c8000x
        https://cdn.badcaps-static.com/pdfs/...1931b51c26.pdf
        STD4525:
        230N06L:
        Did you even try searching the web at all at least?
        • abdekader
          • Jul 2014
          • 73
          • Turkey
          Re: Un46c8000x
          thank you budm , but i don't find this IC G5207 in Turkey , Do you know IC the same work this IC please
          • tibimakai
            • Jan 2012
            • 3680
            Re: Un46c8000x
            Some components are available, only from China.
              by sam_sam_sam
              03-31-2024, 02:12 PM
            • cheeky2
              Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
              by cheeky2
              This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
              I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
              Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
              06-15-2025, 05:12 AM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • CMCM
              Russound CA4 Power Supply Repair
              by CMCM
              Hello Everybody,
              Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
              Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
              The outputs marked 12v and 20v are all measuring only 1v.
              The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
              The capacitors physically look clean (no bludgesor leaks) and...
              07-03-2025, 01:12 PM
