Panasonic TC-P50G20 SC Board
+ More Options
Posts
  • Jer
    • May 2015
    People,
    I'm really sorry for reposting what has had like a thousand links (seriously, I've read 5 different posts on this).
    I've determined as you would guess that my panel has the SC board failure.
    It was giving a 4 blink code. Unplugged SC kept giving 4 blink. Unplugged the SD and all of a sudden I've gotten a 6 blink code. So that all makes sense even according to the service menu.
    This is where I get lost. I have no idea how I should go about testing the board to figure out what is and is not working. I've read posts where there were suggestions. I've got the service manual. But I struggle with the basics. How do I use my multimeter to determine whether it's bad or not.
    I've watched a few youtube videos. But I'm still not 100% clear. The boards are either non-existent or super expensive. Either way, I thought this would be a great chance to learn something new. I just really don't know where to start. I'd really appreciate any assistance and suggestions you all can offer. Even if it's simple links to videos/pages for me use to figure it out for myself.
    https://www.badcaps.net/forum/showth...light=tnpa5081
    https://www.badcaps.net/forum/showthread.php?t=26322
    I've been reading these and a few others. It totally seems possible. Though perhaps expensive? I figured this would be a good chance to also learn how to solder, because it's already broken so who cares if I screw it up more, but ultimately I'd really like to fix it. I really wish it was simply just a bad cap with oozing liquids. I can fix that. Sadly it is more.
    Cheers,
    Jer
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50G20 SC Board
    Originally posted by Jer
    People,
    Cheers,
    Jer
    not really a beginners job if you have little soldering experience. easy to permanently destroy the copper tracks so if you really want to get it going you need to perform the sd/su buffer board resistance checks to make sure they're ok and moduslink pts do repairs. you just missed a 25% off sale which would have been handy. they do have sales from time to time but you'd have to check weekly on their site to catch them
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
      After all of...
      07-13-2024, 08:14 PM
    • canadaboy25
      Panasonic TC-P54VT25 No image. A or D board?
      by canadaboy25
      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
      01-17-2021, 01:06 AM
    • tiku
      Panasonic TH-L32C30D P-Board (1 Blink-Backlight_SOS)
      by tiku
      Hello Friends, i am having this model Panasonic TH-L32C30D, suddenly when i switch on, it went on One Blink, after looking at the service manual it says Backlight_SOS, I can see the menu on the tv screen for few seconds in the dark with the help of flashlight Before it goes into blinking cycle.
      I was having a backup P-Board which i replaced it and now its working fine, but i need to repair my faulty P-Board, as now its getting dificult to find any type of spares of this model, so can any friend who is master in Panasonic Repair, be kind enough to guide me or tell me which component should...
      09-05-2021, 05:02 AM
