Hisense LCD 32W58
+ More Options
Posts
  • burntfingers
    • Jan 2011
    • 148
    Hisense LCD 32W58
    Supplies OK, screen lights on, screen working, but no signal, no menu.
    I don't want to tell customer it is the expensive signals board - is it?
  • mmartell
    • Oct 2013
    • 3189
    Re: Hisense LCD 32W58
    Depends what you mean by "screen working". Do you have sound and did you check the tcon fuse ?
    • burntfingers
      • Jan 2011
      • 148
      There is nothing on screen, no menu, no stations, no sound too.
      It is dead, except that it reflects a little light from the screen lamps.
      Didn't check the fuse.
      • mmartell
        • Oct 2013
        • 3189
        Your information is a little thin. You don't say that you used an external audio source connected to the tv and cycled through the inputs so at this point I am still unsure whether you have sound or not.
        Check the tcon fuse first. Then verify that the unit is not producing sound. If there is indeed no sound the main board is likely the problem.
        Have you verified all voltages to be good ?
        • burntfingers
          • Jan 2011
          • 148
          OK, thanks; appreciated.
          Going to check what I can, and come back.
          • burntfingers
            • Jan 2011
            • 148
            Yes, fuse on t-con panel blown up; bridged it and gone again [had ribbon cables disconnected - as per picture].
            • mmartell
              • Oct 2013
              • 3189
              Sounds like a dead short somewhere which could be difficult to find. You can start by checking diodes and transistors for shorts, even the voltage regs. Has this set been messed with before ?
              • burntfingers
                • Jan 2011
                • 148
                No, it was not touched before - this was its first fault.
                I already found the culprit - the regulator transistor UP5, to the left of the panel, with AQU913 printed, don't know what that means - see picture.
                In any case, panel will have to be replaced, I think, and I already contacted agent - waiting for price and availability.
                Thanks very much for your clue.
                  LCD LED TV Service Menu Codes
                  ALL LCD LED TV SERVICE MENU CODES
                  Service Menu Code with Board Name
                  China Universal Board / Jumper Board Service Menu Code
                  Changhong Ruba Service Menu Code
                  Ecostar LED TV Service Menu Code
                  Orient LED TV Service Menu Code
                  Haier LED TV Service Menu Code
                  TCL LED TV Service Menu Code
                  Samsung LED TV Service Menu Code
                  LG LED TV Service Menu Code
                  Videocon LED TV Service Menu Code
                  Supra LED TV Service Menu Code
                  Toshiba LED TV Service Menu Code
                  Symphony LED TV Service Menu Code
                  Veste/ LED TV Service Menu Code...
                  10-31-2024, 03:58 AM
                • Yehuda170
                  ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                  by Yehuda170
                  original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                  replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                  now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                  with original broken screen i can see in device manager touch screen in human interfaces
                  but with the new screen it's not showing in device manager
                  is it lenovo blocking it? is it driver missing?
                  I²C is a headache
                  07-14-2023, 01:29 AM
                • smic717394
                  by smic717394
                  07-25-2024, 10:16 AM
                • Runlinc
                  Hisense 55E76GQTUK screen removal?
                  by Runlinc
                  Hi all, I need to change the backlights in a Hisense 55E76GQTUK. The screen is glued to the chassis, what is the easiest way of delaminating the screen from the chassis please?
                  also what double sided tape would you recommend to glue it back in? ….. or is that a question to ask once the screen is out in one piece?
                  Many thanks for any ideas you have.
                  04-09-2024, 10:02 AM
                • Chrissygizmo
                  by Chrissygizmo
                  02-10-2025, 12:33 AM
