Anything I should know about my new used WEGA?
+ More Options
Posts
  • Logistics
    • Apr 2007
    • 721
    My cousin just gave me his old 27" WEGA. Only disappointment is that compared to my nice, old Mitz, the sound is pretty poor... makes me look forward to fixing my Mitz. But it does have Component inputs, which I have nothing to test it with, now. When my bro moved out, due to getting married, I agreed to let him take the Xbox. ಠ_ಠ Oh, well.
    When I turn this WEGA on, it has the biggest, loudest *WOOOMMM* sound I have ever heard on a TV's initial power-up. But then, the plastic casing is very prone to reverberation. I am considering putting pieces of dynamat on the inside because it is so bad. I imagine just the sound from it's own speakers must quake the entire shell. I noticed it has a 16:9 Enhanced mode. I guess that means it's not actually native? Any suggestion for the type of DVD player I should get for use with this TV? I don't want to buy something overkill, but at the same time I want it to actually utilize my TV's abilities.
    I think I gave my S-Video cable away to a friend, so I haven't been able to see if it can accept the 480p from my Dreamcast's VGA-Box. (Yes, I said 480p, and there is an old trick to making the DC output 480p, using the S-Video output of the VGA Box. Otherwise, it will simply output 480i.)
  • stevo1210
    • Oct 2006
    • 4156
    Re: Anything I should know about my new used WEGA?
    That loud "WOOOMMM" noise is actually very normal for the Sony WEGA TV. I have one here and it makes the exact sound on startup. Apparently it's to discharge the static from the display.
    • Maxxarcade
      • Jul 2006
      • 973
      You are hearing the degaussing coil. Almost every Sony TV and monitor I've had is the same way. They need powerful coils because the glass is thick, and the small aperture grille wires are hard to demagnetize evenly.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        thats true. these are good tvs anyway last many years as far as i have seen. the speakers are usually mediocre though and should look into a home theater solution.
        last time i was looking at dvd players the toshiba ones were highly rated.
        wouldnt dynamat also increase the heat insulation? i wouldnt recommend messing with that.
        • Maxxarcade
          • Jul 2006
          • 973
          The only weakness I've seen with newer Sonys is the picture tubes. They get weak in a few years, and the picture starts flashing on and off from the IK circuit.
          Their newer projection CRT's also shorted out frequently, in fact I have a 2004 widescreen projection tv that has a shorted blue CRT.
          Sony recently closed their projection TV line, and now only makes LCD's from what I've read.
          I've always been a fan of Trinitron computer monitors, in fact now I have a GDM-FW900. But my next monitor will be an LCD. They look so much better than CRT's these days. No longer are they the washed out, dim and fuzzy things they used to be.
          • Logistics
            • Apr 2007
            • 721
            I'm only talking about some little pieces of Dynamat, here and there. Practically, the entire backside of the shell is nothing but a huge plastic vent. I mean, literally, everything behind the screen portion is littered with vent slots.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              i think the led backlight technology will be very interesting. i am very much into uniform brightness over the screen. I will hold off getting an lcd tv until they bring that to the mainstream.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                thats cos it fucking hot
                anyway if you think that woooommm is bad you should hear an APC rackmount ups
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  you will have to apply dynomat to the aperture grille to silence the set.
                  unfortunately it tends to block the electron beam and does not survive the 500f heat during evacuation.
                  • Logistics
                    • Apr 2007
                    • 721
                    No, no. Hehehehe! I don't mean the WOOM sound, itself. The plastic shell of this set is very loud, in that it reverberates from the slightest tap, and coming from a DIY audio scene, I'm pretty confident it resonates from even it's own set of speakers. This is not acceptable in my opinion. Even if I was to run external speakers from a stereo, I would not want the plastic shell making any noise.
                    Huge LoL at your post kc8adu.
                    • hardwareguy
                      • Jun 2006
                      • 405
                      I hear you on that! LED lit DLP IS out and it's cost is reasonable.
                      NTSC dies in just a little over a year over here in the US....... 2/17/2009! Hopefully I can get a new TV before then, I don't wanna waste cash on a converter box.
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        i am still waiting on my hp 2510p order.....with led
                        • JEWilson
                          • Sep 2007
                          • 369
                          • Scotland, United Kingdom
                          Y - I'm a fan of Trinitron
                          As to PC monitors - I have gone through an HP P1120 and am now onto
                          an HP P1130. The P1130 is my second one as the first, bizarrely failed
                          just a week shy of its warranty expiring (that is, three years) - bizarre!
                          Anyway HP replaced that and gave me a new one - is that why I paid
                          almost £1000 for? You bet!
                          As to TV, I have a SONY KV-M14TU and KV-M19TU - these are quite old.
                          I haven't used the KV-M19TU for some time but it is as good as new in terms
                          of pic quality as it has seen very little use.
                          The KV-M14TU I picked up second hand from an auction. It was listed as
                          not working but I found this to be cold joints near the flyback. Anyway,
                          that has worked without any problems for near 12 years - coo..ool.
                          As these are both 5:4 aspect ratios they cannot be used for widescreen.
                          I gave my Father a Sony 24LS35U FD Trinitron WEGA 24-inch in sliver.
                          This may be the smaller model than the one willawake is referring to - dunno.
                          I gives an excellent picture and has the 16:9 Enhanced as willawake refers to.
                          As this is a badcaps forum, it may be in the very near future, my KV-M14TU
                          (T - teletext haha) will require a revisit, service and perhaps a recap.
                          Almost certainly, those cold and cracked joints will have some siblings...
                          Anyway, I intend to hang on to this for use with my webcams and video
                          server (when I get these up) as this can be tied into a alarm systems.
                          I guess I'm a late adopter of LCD monitors for PC based work, an even later
                          adopter for LCD/DLP/Plasma technology for TV or Video work.
                          Any members have views on this?
                          • JEWilson
                            • Sep 2007
                            • 369
                            Oops...
                            Not willawake in last post re - Enhanced 16:9, should be logistics
                            Sorry
                            • chipper
                              • Aug 2008
                              • 95
                              I've pretty much given up on Sony televisions and their monitors , even though they did seem to be the ultimate back in the late 90's. If you really tech Sony , you have to come to realize that Sony has been a complete market wide supplier of all types of electronics.
                              I have one of their really old (bar televisions) , can't recall the model # . It's a 50" , 3 tube set that sends the picture to a mirror , and then it reflects back onto the screen. When I first got it , it wouldn't power up . When a professional tech friend of mine looked at it he took 1 look at the huge interior pcb and said " it will cost you a fortune to get running and may go on costing you" Even though he did say that most components at the time were all Sony anyways of some sort if they were any good.
                              So , I gutted it and installed a working Toshiba of the same era and type to it. Worked just fine and didn't have a single problem since the early 90's. It can project a full wall sized picture but the resolution is nasty. Then , in the late 90's I bought a 22" Mitsubishi monitor (Trinitron Tube) , it too blinked off one day and the repair on the tube was over $500 , so out it went.
                              These days it's not the top of the line that is making heads turn , it's the cheaper brands that are concentrating on reliability and cost of repairs. If the manufacturer can keep you running , it can keep you buying their products. There are , after all some people having the exact same problems after dishing out as much as $4000 on a plasma or lcd tv , as someone who spent less than $1000.
                              The Toshiba 42HL167 is an hdtv lcd that has all the bells and whistles that other newer tv's have , yet the price is far more reasonable. In fact , right now for the same price as the 2007 model you can choose a 2008 model. We are talking full hd with 1080p , while the new standard is about to change in Feb./09. Consequently some new tv's are coming out that only support 1080i (not 1080p) with the same pricetag.
                              The 42&47HL 167 Toshiba are chock full of features , I should know I have a 42HL167 now. While their cousins : the 42&47HL67 falls just short for no apparent reason due to the 1080i issues.
                              I would say if you want to spend money on a tv soon , now is the time to buy the Toshiba sets ( 42HL167 REGZA ) is like having another computer with your tv while it also allows it to be a monitor as well.
                              • homerging
                                Sony trinitron Wega KV-HR36 picture issues
                                by homerging
                                could anyone please tell me what is likely to be causing the CRT picture quality issues as shown in the attachments and what it'd take to fix it if that is possible?
                                The picture has a greenish tinge, colour scan lines are separated and there can be shimmering and the bottom can be missing at first. It has slowly gotten worse over time.
                                It is worst when first turned on and slowly improves but not resolves over a period of approximately 90 minutes. Warmer room temperatures possibly have a positive influence....
                                08-05-2022, 07:06 AM
                              • bulkchart32
                                i cannot get rid of the interference in the video on this 1.1v and i have tried everything!
                                by bulkchart32
                                i recapped the entire foxlink psu with rubycon caps of the exact uf needed. i also purchased a delta psu to see if the different brand would change anything and it did not. i recapped the entire motherboard except for about 5 of the 22uf caps. i used rubycon on everything except the five in front of the processors. i used 5 nichicon polymer caps there. i soldered a wire to each screw hole of the psu and soldered one wire to the metal outer shell and one to a screw hole on the motherboard(to make sure it was all grounded well). i also recently tried disconnecting the power cables from the dvd drive...
                                06-19-2025, 02:37 AM
                              • Alfredmanner
                                Samsung UE65HU7500T 3D issues after replacing LCD
                                by Alfredmanner
                                Hi guys I have a weird problem, I recently acquired a Samsung 65" UE65HU7500T UHD 3D TV, it had a broken screen so I had to source a replacement. I did so and replaced the screen but now everything works perfectly except the 3D function, the 3D (2D to 3D conversion of live TV, PS4 3D, PS4 Blu-Ray movie 3D, PC Blu-Ray 3D, NVIDIA 3D vision,) all come out as blurry, I've tried 4 different pairs of Samsung active 3D glasses model SSG-5100GB, all present the same issues, it's like the 3D glass is not doing its job, the TV picks up the 3D glasses and pairs there 3D glass and switches to 3D mode...
                                01-19-2021, 09:44 AM
                              • Roni3xmom
                                Sony wega KDF 55E2000
                                by Roni3xmom
                                Hi. Yes, these tv's are still alive. I bought mine in 2006 and it has been working great. We have had to replace the bulb but no other problems. Until a few weeks ago it started to get blurry and now it's like doubling. I looked it up and it looks like ghosting. But then the colors started going off to the left a little bit and we are wondering if it is convergence. We have the remote and are able to get into the service menu, but we aren't sure which values to change.
                                Thanks for any help.
                                Roni
                                04-15-2016, 08:28 PM
                              • Paul678
                                Possible Sony Wega KV-24FS120 Purchase
                                by Paul678
                                Here's what the owner wrote me:
                                "SONY WEGA.... FLAT SCREEN....GETS LINES GOING ACROSS IT ON THE BOTTOM WHEN YOU TURN IT ON.... SOMETIMES THEY GO AWAY AND THE T.V. IS PERFECT.....$40".
                                It's only 24", so I know I'm not gonna pay $40, but
                                I just wanted to know what if you all think this one is
                                fixable, as I usually buy TVs with power supply issues.
                                Could this be one of those ribbon cable to the panel issues
                                that are un-repairable?
                                Thanks in advance......
                                08-16-2012, 01:00 PM
