Sony kdl-40w3000 with 13 blinks but panel power on
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    When I plug this TV in, I hear the relay click, panel does not turn on, there is no LED status at all, and after 4 seconds or so relay clicks out. Again no LED status after it turns off. While it is on (for those few seconds), I can read steady 6V and 12V. I cannot see any other voltage point to test. While it is on there is an orange LED on the FB1 board (1-873-846-14) that turns on, and they blinks 3 times after which, TV shuts off. (not sure if that is relevant)
    Then, when I press the power button for the first time after it was plugged in, the relay clicks in again, and 2 seconds later I get the panel to turn on for about 2 seconds, after which the TV shuts off again (nothing shows on the panel). Then I get repeated 13 blinks from the stand-by LED. While it is on, during this session, I can hear a slight hum from the DF1 Board (1-873-815-12) while the panel is on. If I press the power button again, the process repeats.
    From my research, 13 blinks seem to indicate bad inverter board (SSB400WA20S) which could also indicate bad panel, but since the inverter board does turn the panel on for few seconds, I am not sure what to make of it.
    Thoughts?
    Re: Sony kdl-40w3000 with 13 blinks but panel power on
    More likely to be bad lamps:
    See the videos and make the measurement, it is the same topology.
    https://www.badcaps.net/forum/showpo...1&postcount=74
    • Pioneerx01
      • Apr 2015
      • 241
      • US
      100% correct. Thanks. I have taken apart the panel and one of the tubes was burned out. How are these measured if I want to buy a replacement? This one is ~36" from metal tip to metal tip and 3.4mm thick. Where is a good place to buy replacements?
      Thanks again.
        Thanks for the follow-up on the fault finding.
        Try this place:
        http://www.ccflwarehouse.com/
        If you see some with blackened end, you should replace them also.
        • mauda
          Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
          by mauda
          I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
          Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
          05-21-2023, 11:56 PM
        • tec3000
          Sony LED 65X9005A shuts down after few seconds - looking for help
          by tec3000
          Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
          I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
          03-20-2024, 07:29 AM
        • r3vsEngIT
          Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
          by r3vsEngIT
          65x900h with the panel from a 65x930d.
          900H: model yr 2020, Samsung panel
          930D: model yr 2016, Innolux panel
          spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
          the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
          07-11-2023, 11:11 AM
        • AK_777
          Sony KD-65A1 Repair – 4 Red Blinks Error
          by AK_777
          Hi everyone!
          I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
          Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
          02-20-2025, 04:15 PM
        • jchon
          Sony A1e 5-blinks help
          by jchon
          Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
          I found the service manual, which was critical to know where to probe.
          https://www.manualslib.com/manual/20...1e-Series.html
          With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
          Unfortunately the 5-blinks...
          06-28-2023, 11:52 AM
